Personaly I find the rear end fairly stable and if it does start to wander it comes out fairly slowly and is easy to correct...
If you'd tried doing that same braking manover in a 205 you would have been pointing backwards in the time it takes to blink.... If your fairly hard into a corner all you need do is lift off the throttle and the backs stepping out so you can imagine what it'd do if you braked...
Admittedly you get alot less feedback from the
ibiza than you do a 205 so its not quite so easy to know what the car is gonna do..
The
ibiza does feel a bit loose and it does wander around quite alot but at no time would i call it scary...
I've had my balls in my mouth on only a few rare occasions in the
ibiza, most of which were when I first got the car and I was kinda expecting more from the car in the handling stakes....... But it was still the amount of understeer that gets me.. It just has so much weight over the front wheels it just struggles with front end cornering grip...
