Never changed mine, just put it in push the pedal down and pull the plunger out, then try the pedal a few time so it sits right.
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Turned out to be a cheap faulty part!
The genuine SEAT switch (which looked different to all I've seen before - it was very square) slotted straight in and works perfectly! Easy peasy!
Hi, did you just plug the connector in, insert the switch into the pedal and all was good or did you have to press the pedal down and pull the rod out ?
Theres a great guide on vw vortex forum showing exactly how the switch should be set when installing, very useful...
Ian
Link it up then
or pm it me you can't![]()
you can't pm either i think
post it but use xxxx for the http
