Ibiza timming chain
Anthony Webb
Hi all, any body out there having problems with 1.2 AZQ ibiza.
Poor power, fuel economy fault code P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem, clear code fault still occurs MAP sensor supply signals and manifold preasure tests good
throttle body cleaned and re-adapted,compressions good 150psi all cylinders.
Timming checked exhaust camshaft out by three teeth. Modified chain tensioner and guides suspectable to jump from cold or when turning engine off as exhaust cam kicks back.
Starting to get a few problems with these engines keep an eye out folks.
mrcoyote
See no evil...
Jul 26, 2004
2,624
Can we have this in English please? You know, properly constructed sentances and all that nonsense?
Anthony Webb
Plain as it is timming chain tensioner failing causing valve timming to jump, is that ok
muddyboots
Still hanging around
Oct 16, 2002
5,739
Well I understand it:
The timing chain has a tendency to jump a few teeth, sending the camshaft timing out.
Anthony Webb
claudefrog said:
its not a question.. the guy is telling people some good info.. about running problems and potential resolution for them.
Thanks Claudfrog least u understand, i wont bother next time.
EdButler
713
Sheffield
Ahh i think this is what happened to SirSparksters at some point! Good bit of info mate thanks, especially useful as many Mk4's are starting to head out of warranty.
Id also expect the forum 'regulars' to read the post TWICE before flaming the poor guy; im no techie, but i understood. It is this sort of info we all need...
mrcoyote
See no evil...
Jul 26, 2004
2,624
It wasn't flaming, it was just a request for posts to be properly constructed. If you need to read it twice, then it's not really clear is it?
gazjones
i had this problem on my 1.2 the tensioner faild and car wouldnt start fixed in about two working days.
