Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
I would say cone is better over all on a turbo car. Regardless whether the air is cold is irrelevant. If the air is freezing cold once it goes through the red hot turbo it will turn that into hot air. Turning hot air into cold air is the job of the intercooler.
If running higher than standard power I would say a panel filter inside the standard air box is more restrictive than a free flowing cone filter.
Simple way to test this would be to do a vagcom log on your mass airflow with both cone and panel filters
Must say that's the best excuse for buying an induction kit I've ever heard![]()
Yup MPG will increase with a remap because the engine won't be working as hard to get to the same speeds so engine RPM will be lower
However the saying is power corrupts so you'll be gunning it everywhere with a smile on your face so MPG won't exactly be important![]()
I'm guessing you're AUQ lump?
http://www.ebay.co.uk/itm/SEAT-Leon...rParts_SM&fits=Model:Leon&hash=item3f2a7f670b
or
http://www.ebay.co.uk/itm/Green-Cot...arts_Vehicles_CarParts_SM&hash=item35c9f197b3
I know where my money'd be going![]()
Engine rpm doesn't decrease with a remap. Its just that the engine will produce more torque which will make it easier to get up to speed quickly.
Naa mate. Your right you technically shouldn't have to "thrash" it to get it up to speed as the improved torque should pull you up to your desired speed quicker, your not spending more time accelerating to reach your desired speed therefore saving fuel. But like you say it doesn't work out like that as remap on a turbo car means more boost =![]()
