Right got a bit to update on.
Firstly I attended Spring Performance Car Action Day at Combe.... I haven't looked for any photos so if you have any then please post them up!
The day was pretty wet and I found the Kumho V70A's on a full on wet track are rubbish! The best way I can explain is it felt like driving on the snow, there is a
video on
youtube with two Pug's and I come wheel spinning by but I can't find it now
As the track got drier the tyres actually worked and by the 3rd session the track was dry and the differance in grip was a lot BUT I did notice that my brakes weren't feeling too good and inspection they were worn.... So since Combe and up until today the car is still on axel stands.
I managed to win a set of Speedline Comp 2's on eBay but were in need of a good refurb
Took them to PPS in Hirwaun
I've had two piece discs made up for the front by Godspeed Brakes with that the front & rear discs grooved along with DS2500 pads on the front & back. Once everything was off I had the Brembo's refurbed, luck that I did as they found I had cooked the inner seals!
Got my Speedline's back from PPS
The New Vs. Old Discs
Ordered up a set of Goodridge braided hoses to but on fitting the brakes I found the fronts were too short (I asked for
Mk3 Ibiza Cupra R hoses) which should have fitted but don't! Even the fitment to the Brembo's would ideally be a 90 degree elbow but these are straight
Contacted Goodridge but they not being very helpful at the moment.
The other hoses fitted perfect
Fitted the front discs & calipers
And trial fitted the Comp 2's
And might as well get a pic with the Compomotive MO's
Fitted the rear discs and pads and also removed my studs from the hub of the rears and cleaned them up ready to fit so the new rear discs after I bleed the brakes
Ordered a set of braided hoses from Badger 5 so just waiting on delivery of them now to fit then I can bleed the brakes, fit the studs and then go out for a day to bed the discs & beds in. While waiting on the hoses I fitted some grip tape used on skateboards to the footwells as I'm fed up of marks on the floor and sliding around when it's wet lol.
And on a random look on eBay at GoPro Hero 2 camera's I found a Motorsport Edition going for £187.50 with a buy it now so knowing that was cheap & fancying one for a while I bought that, then when I looked 20mins later the seller had but it up to £199.99 so I think he made a mistake as he also had some up where you could bid for that at that starting price.
