It's been a while since I have updated this and bear with me, I have a bit to do. Been busy with work, working on the snot and arranging my wedding.
Firstly I got to show off my wedding cake topper because I think it's cool as!
Now back to the
Ibiza, all the trouble started at Castle Combe back in September
The kind recovery marshal gave me some parts when he towed me back to the paddock.
One of my big ends decided it wanted to leave the block. Got the car home and looked over my
video footage and watched the oil pressure, going into Folly corner the pressure dropped from 80 to 35psi, the pressure stayed at this for the whole lap and when I got back to Folly the pressure raised back up to 80psi and behaved itself for the rest of the session.
On my second session out coming out go Quarry the Oil Pressure when from 60-35 psi and then back to 60psi, lap later going into The Esses the oil went from 60-30-60-30 and back to 60psi and raising but I felt the engine hold the rev's at about 7k went to back off and BANG!!! Looks to be my oil pump was on its way out, the sump is baffled and never had any problems like this before at Combe which I have been around a good few times now.
Few photos of the bits I found when I removed the sump;
A lot of heat heat developed on rod 4 and its bearing, the big end from rod 4 broke off made its way over to rod 3 which smashed it out of the block.
And the state on my crank, journal 4 is slightly damaged (to say at least).
So the strip down begins;
Engine on route to Saxon Motorsport
One empty engine bay
The after mass of the block giving birth to a broken big end.
Wanted to remove the manifold to have it ceramic coated by Zirotec in Performance White.
Ripped out my flocked dash
To replace it with this sexy looking carbon fibre dash which I was lucky enough to get from RobT when he was selling off all of his goodies!
But I wasn't just going to leave it with fitting a new dash, all the excess wiring that is no longer needed on my car had to go!
So did the heater matrix after reading someone thread on here that used a heater from T7 design instead
The new heater
Had to make a plate up for the heater pipes to fit to the bulk head, had no Aluminium floating around in the
workshop but have got a bit of 2mm thick carbon fibre left over so used that.
The heater bolted in place but I haven't fitted the ducting yet
With the new carbon dash I need to use toggle switches and always wanted to do a push button start so it's the perfect time, bit of the wiring.
And the dash with a few switches in place
