so the little spaniard kicked some french ass then dave ??? lol. christ, imagine the weight in that heavy duty battery. did you get much water in through the new windows as i know you said before when you washed it they arn`t 100% water tight.
wicked track car mate, i mite be wrong but im sure i saw this at 2009's audi day at combe, i was on track in my old blue mk2 golf, was that you?
Anyway car looks great, really wana get myself a track weapon!:happy:
Rained Saturday night and had no water at all in the car and driving home I had the slider open all the way, even had it was raining and nothing :D
Yea I was me, last outing I think before I had the throttle bodies fitted.... had problems selecting gears after my 1st session, before going home I noticed my shift weight was loose and the nut was off :think:
Don't think I'll be doing that day again this year, the non Audi cars were treated like second class all day :censored:
ah yeah i thought it was you, its a pretty unique car isnt it! Yeah i agree ther mate, i was with the guys in the black mk2 ibiza 1.8t, then ther was me in my mk2 golf, and another guy in the black mk1, and we were sort of looked down on all day, even to the point were they made a big deal out of just letting us into the holding area for the track, crappy really it was cheap tho so. . . .
A little update of things to come.
Found a 5 speed Ricardo Dog Box for sale which as been fully rebuilt and a Avanti Plated diff, currently as a 5.08FD but will be changing it to a 4.6 as at the moment it will top out at 115mph lmao with the 4.6 it will top out at 127mph instead but be honest how often do you hit 130mph on a track??
As well as this dog box I am always getting a Ringspann Motorsport Shifer like the one below
the motorsport shifter in that pic? 4 times more than a B&M short shifter :D
The Ringspann one is the closest you going to get to the VW Motorsport one (they not made no more but Ringspann do a perfect copy)
i think it might be a good investment for me for when i change to cable linkage. takes about a second to change gear at the minute.
Got the very same gearnob as shown in the picture above ;) How much better is the ringspann compared to the B&M shifter? What are the diffrences between them?
B&M
Motorsport Shifter
See the differance
The Motorsport shifter is closer to the steering wheel, well higher and offers better shifting but you will need to run the cables different as you can see in the pic
Got a question for you Dave, is it worth swapping from a K&N panel filter to a Pipercross Induction kit?
// BubbleBoy ;)
people on here will tell you straight away to do a panel filter like you have now and drill your air box but to be honest I found my pippercross induction with a tidy air feed did a go enough job and sounded nicer than a drilled box.
nice project bro can u plz tell me exactly all parts u get with all info about it and see me if u have video for the car from 0-100 , 0-200 and 100-200
what about the exhaust hm the pipe u make 2 mm or 2.5 mm or how mach and the raims how mach inch the o.z and the other one coz i need to use 16 inch one
Look back on this thread and you will find all thje answers!
Here's the spec list of the work I had at Saxon Motorpsort:
Jenvey Direct to Head Throttle Bodies
45mm Diameter
130mm Plenum (butterfly to bell end)
73mm Trumpet (face to bell end)
VXR Injectors
440cc
Ultra Sonic Cleaned
Kent Cams
Duration 278 deg
Valve Lift 11.04
Full Lift 108 deg
Valves Springs
75lbs @ 33mm
198lbs @ 21mm
19.5mm Chrome Silicon
Valves (Intake)
One Piece
32x6.95x95.5
Under & Back Cut
Nitrided
Valves (Exhaust)
One Piece
27x7x98.2
Under Cut & Polished
Nitrided
DTA S40 ECU
Custom map against revs/load
People on here will tell you I'm not interested in 1/4 miles times and 0-60mph, etc.... as long as it goes well on track I'm happy!
What you think are OZ Racing rims and the standard 16" Ronal 16v alloys which you will find on all the 16v Ibiza's the Compomotive alloys now are ET35 with 15mm spacers on the rear, 16"x7J wide!
thx bro for all this info but let me ask about some thing your rims 4 hole but here abf susp 5 hole u changed it or its origenal
