Here is how to do it, turn the cars ignition on and wire up your cable and start the VAG-COM software... from the main VAG-COM screen go for "Select control module" and on the next screen select "09-Cent. Elect." it will then connect to your cars central electronics menu and you then want to select "recode" at this point you have two editable fields... the one we are editing is the software coding one. The original code on mines was 16396 ... to add the comfort wipe function I added 8192 to that, so changed the code to 24588 and clicked "Do It!" At this point I clicked "Coding" again to make sure that it had changed. Basically take the key and cable out - start the engine and put your front wipers on and then select reverse gear - the wiper should come on.
What makes you think it only works on pre face lift?
Fancy tryin it on my car? Then you'll know![]()
Looks great mate, love the colour when it's gleaming!
Don't know if I should go back to Seat about it. I certainly won't be taking it to any Arnold ***** garage, I don't imagine they'll help much.
Plus I have covered it up now. Maybe I'll go to somewhere like Livingstones in Uddingston, see what they say.
.G.
Sent from my GT-I9000 using Tapatalk
Did you ever go to seat about your paintwork?
