billyhas
272
kidderminster
New to vag com so bear with me.Can someone take a look at thes logs and tell me if all is ok.Settings used were B6 T5 using tesco 99.I understand the the timing could be advanced further having shown no cf in group 020 but was unsure about group 115.I believe my peak boost to be 19psi which seems a little low
Code:
	Group A:	'020				Group B:	'115
		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME
Marker	STAMP	°KW	°KW	°KW	°KW	STAMP	 /min	 %	 mbar	 mbar
	2.36	0	0	0	0	2.06	2640	145.1	2160	1840
	2.97	0	0	0	0	2.66	2840	175.9	2190	2250
	3.57	0	0	0	0	3.27	3080	172.2	2210	2090
	4.17	0	0	0	0	3.87	3320	187.2	2250	2190
	4.78	0	0	0	0	4.47	3560	191.7	2280	2230
	5.38	0	0	0	0	5.08	3800	165.4	2050	2070
	5.98	0	0	0	0	5.68	4040	136.1	1810	1760
	6.59	0	0	0	0	6.29	4160	113.5	1560	1460
	7.19	0	0	0	0	6.89	4320	122.6	1990	1480
	7.79	0	0	0	0	7.49	4480	169.2	2070	2050
	8.4	0	0	0	0	8.1	4680	175.9	2300	2170
	9	0	0	0	0	8.7	4920	191.7	2290	2320
	9.6	0	0	0	0	9.3	5120	189.5	2270	2310
	10.21	0	0	0	0	9.91	5320	191.7	2260	2260
	10.81	0	0	0	0	10.51	5520	187.2	2250	2230
	11.41	0	0	0	0	11.11	5680	182.7	2240	2200
	12.02	0	0	0	0	11.72	5840	182.7	2230	2170
	12.62	0	0	0	0	12.32	5960	166.2	2220	2170
	13.22	0	0	0	0	12.93	6120	167.7	2220	2130
	13.84	0	0	0	0	13.53	6280	174.4	2220	2080
	14.43	0	0	0	0	14.13	6400	169.2	2230	2070
Actual is struggling to meet requested boost, so it looks like you have a boost leak. Like you said, the timing could be knocked up a tad. Aim for cf's of around 3 in the warm weather but first I would check that every single boost hose is clamped tight and go and do some more logs from 2k-redline in 4th gear without letting off the gas.
Log blocks -
020 and 118
114 and 115
002 and 031
You could also check block 032 for your long term fuel trims.
Thanks for the info.Had a poor resullts on Performance Torque rollers which supprised me a little only made 246 bhp and 268 ftlbs ,however after logging group 115 which seems to confirm a boost leak.After close inspection ,the pipe that connects the dv to the charge pipe had worked loose at the dv end.i'll do some more logs and confirm this was the only problem
Something aint right with the boost, It requests max boost from realy low down then at 3.5k requested boost drops right down, then requested starts to rise.
Do you have a boost gauge? If so does the boost look to be surging/fluctuating?
I do have a boost guage but have not noticed anything unusual.I plan to do some more logs tomorrow now the boost leak is fixed.I will post my results.Do i need to log anything other than th following.
020 and 118
114 and 115
002 and 031
020 and 118
114 and 115
002 and 031
Those will be enough mate.
More logs here.Please give me some info as to how my car is running and possible ways to improve on these results;
Code:
27	April	2009	18:59:25		B6 T7
	1.8l R4/5VT         0001
Group A:	'003				Group B:	'020
	RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME					TIME
STAMP	 /min	 g/s	 %	 °BTDC	STAMP	°KW	°KW	°KW	°KW
0.29	2120	40.72	74.1	20.3	0.01	0	0	0	0
0.91	2200	47.64	100	18.8	0.59	0	0	0	0
1.51	2360	48.92	99.6	20.3	1.2	0	0	0	0
2.11	2480	52.64	44.7	22.5	1.8	0	0	0	0
2.72	2640	73.97	100	18.8	2.41	0	0	0	0
3.32	2840	99.03	100	10.5	3.01	0	0	0	0
3.92	3080	89.72	100	7.5	3.61	0	0	0	0
4.53	3320	117.69	100	8.3	4.22	0	0	0	0
5.12	3560	129.67	100	8.3	4.83	0	0	0	0
5.73	3800	133.17	100	10.5	5.43	0	0	0	0
6.34	4040	143.64	100	10.5	6.04	0	0	0	0
6.94	4280	154.03	100	11.3	6.64	0	0	0	0
7.54	4520	161.58	100	13.5	7.24	0	0	0	0
8.15	4680	167.58	100	9.8	7.85	0	0	0	0
8.75	4960	171.33	100	12	8.45	0	0	0	0
9.35	5120	182.19	100	11.3	9.05	0	0	0	0
9.96	5320	182.69	100	11.3	9.66	0	0	0	0
10.56	5520	189.56	100	12.8	10.26	0	0	0	0
11.16	5680	189.69	100	11.3	10.86	0	0	0	0
11.77	5840	191.86	100	12	11.47	0	0	0	0
12.37	6000	194.03	100	12	12.07	0	0	0	0
12.97	6120	196.53	99.6	12	12.67	0	0	0	0
13.58	6240	196.92	100	12.8	13.28	0	0	0	0
14.18	6360	196.83	99.6	15	13.88	0	0	0	0
14.78	6480	192.22	99.6	13.5	14.49	0	0	0	0
15.4	6600	197.31	100	15	15.1	0	0	0	0
27	April	2009	19:05:27
	1.8l R4/5VT         0001
Group A:	'115				Group B:	'031
	RPM	Load	Absolute Pres.	Absolute Pres.		Lambda Factor	Lambda Factor	Bin. Bits	Bin. Bits
TIME					TIME
STAMP	 /min	 %	 mbar	 mbar	STAMP
0.01	2360	85.7	1430	1150	0.3	0.914	0.984
0.59	2480	105.3	1660	1360	0.91	0.969	0.984
1.21	2640	130.1	2170	1630	1.51	0.961	0.953
1.81	2840	157.1	2170	2010	2.11	0.953	0.945
2.4	3040	176.7	2180	2150	2.72	0.93	0.945
3.02	3280	187.2	2220	2250	3.32	0.945	0.93
3.62	3560	191	2280	2220	3.92	0.914	0.906
4.23	3800	191.7	2310	2250	4.53	0.883	0.875
4.83	4040	187.2	2330	2290	5.13	0.852	0.86
5.43	4280	191.7	2330	2250	5.73	0.844	0.86
6.03	4520	186.5	2320	2320	6.34	0.844	0.86
6.64	4760	184.2	2290	2300	6.94	0.852	0.86
7.24	5000	187.2	2280	2240	7.54	0.852	0.86
7.84	5200	185.7	2260	2200	8.15	0.86	0.86
8.46	5400	182	2250	2190	8.75	0.86	0.86
9.05	5600	174.4	2240	2180	9.35	0.852	0.86
9.65	5760	171.4	2230	2120	9.96	0.828	0.86
10.27	5920	191	2220	2000	10.56	0.86	0.86
10.86	6080	158.6	2220	2100	11.17	0.844	0.86
11.47	6200	160.2	2220	2070	11.77	0.836	0.86
12.07	6320	157.9	2220	2040	12.38	0.852	0.86
12.67	6440	160.9	2220	2020	12.98	0.828	0.86
13.29	6560	160.9	2230	2030	13.58	0.852	0.86
Monday	27	April	2009	19:12:42
1ML 906 032 		1.8l R4/5VT         0001
	Group A:	'118				Group B:	'032
		RPM	Temperature	Load	Absolute Pres.		Lambda	Lambda	Bin. Bits	Bin. Bits
	TIME					TIME
Marker	STAMP	 /min	°C	 %	 mbar	STAMP	 %	 %
	0.25	2240	22	100	1560	0.55	0.9	4.7
	0.86	2400	22	97.3	1730	1.16	0.9	4.7
	1.46	2600	22	95.3	1980	1.76	0.9	4.7
	2.06	2840	23	69.8	2300	2.36	0.9	4.7
	2.65	3040	21	76.1	2110	2.96	0.9	4.7
	3.27	3280	21	75.7	2180	3.57	0.9	4.7
	3.87	3520	22	76.5	2220	4.17	0.9	4.7
	4.48	3760	23	76.9	2200	4.78	0.9	4.7
	5.08	4000	23	84.7	2230	5.38	0.9	4.7
	5.68	4240	24	84.3	2330	5.98	0.9	4.7
	6.29	4440	24	83.5	2320	6.59	0.9	4.7
	6.89	4680	25	83.9	2290	7.19	0.9	4.7
	7.49	4880	26	84.7	2290	7.79	0.9	4.7
	8.1	5080	27	84.7	2230	8.4	0.9	4.7
	8.7	5280	28	84.3	2220	9	0.9	4.7
	9.3	5440	29	86.3	2180	9.6	0.9	4.7
	9.9	5600	30	94.5	2150	10.21	0.9	4.7
	10.51	5760	30	95.3	2190	10.81	0.9	4.7
	11.11	5920	31	95.3	2060	11.41	0.9	4.7
	11.72	6040	32	95.3	2090	12.02	0.9	4.7
	12.33	6200	33	95.3	2030	12.62	0.9	4.7
	12.93	6320	33	95.3	2080	13.22	0.9	4.7
	13.53	6400	34	95.3	2030	13.83	0.9	4.7
Code:
Wednesday	29	April	2009	19:46:01
	Group A:	'002				Group B:	'114
		RPM	Load	Inj. On Time	Mass Flow		Load	Load	Load	Load
	TIME					TIME
Marker	STAMP	 /min	 %	 ms	 g/s	STAMP	 %	 %	 %	 %
	0.01	2200	118	11.22	54.47	0.31	158.6	156.7	124.1	99.6
	0.61	2400	131.6	12.58	64.44	0.92	172.9	171.6	140.6	95.7
	1.22	2600	151.1	14.96	82.36	1.52	177.4	176.1	164.7	85.9
	1.82	2800	183.5	18.02	111.03	2.12	180.5	179.1	187.2	68.2
	2.42	3080	174.4	16.32	98.08	2.73	183.5	182.1	178.9	72.9
	3.03	3320	189.5	17.68	123.31	3.33	186.5	185.1	191.7	73.7
	3.63	3600	191.7	18.36	130.28	3.93	188.7	186.6	188.7	74.5
	4.23	3840	188.7	18.7	140.22	4.54	191	189.6	188.7	74.9
	4.84	4080	191	19.38	149.61	5.14	191.7	189.6	186.5	74.5
	5.44	4360	188.7	19.38	154.58	5.74	191.7	191	184.2	74.1
	6.05	4600	184.2	19.38	161.83	6.35	191.7	191	184.2	75.7
	6.65	4840	183.5	19.38	168.75	6.95	191.7	191	178.2	74.1
	7.25	5040	181.2	19.04	178.03	7.55	191.7	191	182	75.3
	7.85	5280	178.9	18.36	183.72	8.16	191.7	191	181.2	83.1
	8.46	5480	182.7	18.7	186.61	8.76	191.7	191	178.9	95.3
	9.06	5680	181.2	19.04	191.86	9.36	191.7	191	174.4	95.3
	9.66	5840	181.2	19.04	192.78	9.98	191.7	191	175.9	95.3
	10.27	6000	173.7	18.02	190.92	10.57	191.7	191	164.7	95.3
	10.87	6160	165.4	17.34	195.25	11.17	191.7	191	162.4	95.3
	11.48	6280	165.4	17	195.58	11.78	191.7	191	169.2	95.3
	12.08	6400	168.4	17.34	199.06	12.39	191.7	191	162.4	95.3
	12.68	6520	155.6	14.62	194.56	12.98	191.7	191	11.3	0
Apologies for not coming back to you sooner.
The load figures in 114, the ecu isn't trying to compensate for anything, but the car just isn't making what's asked of it over about 5280 rpm. That's boost related..... :think:
Ok so it looks like a possible boost leak.Whats the best plan of action for tracing the leak.?I have checked the boost hoses visually but nothing seems to be amiss.I assume the turbo it self is ok.Is it possible the dv is leaking,(Forge 007) its been on the car for 2 years and never been serviced(dont know if its required) .Any help/suggestions would be appreciated
What could be sending the engine into limp mode when ever i select boost 9? Judging by the comments DPJ has made everything seems to functioning correctly until 5200 rpm.Am i right in thinking that requesting more boost than the turbo can deliver would result in limp mode.If this is the case is my turbo shagged
