Not sure if this will help but this is what I did to readjust
- Turn on the ignition (no need to start the engine)
- ensure "Mirror lower when reversing" is selected in the infotainment system
- Turn the mirror control dial to "L"
- select the reverse gear
* important* if the passenger mirror doesn't adjust to the desired position adjust it manually using the control.
_ disengage the reverse gear
The mirror doesn't always return to the normal position until you engage a forward gear and move away.
It would be nice to have this feature available for both sides, but I'm guessing it can't be done without some coding trickery.
Sent from my Pixel XL using Tapatalk
