MK4 Ibiza clock removal???
130 ibiza
I am wanting to remove clocks on my mk4 ibiza to do some soldering to hopefully cure my immobiliser problems, but before I attempt this I was wondering how difficult is it to remove them, is it worth attempting??:think:
Thanks in advance
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
Yep, it's easy.
DISCONNECT YOUR BATTERY!!!!!!!
Move steering wheel fully out and fully down, remove steering collumn trim and instument cluster trim. Then remove the cluster, there are 2 large multi plugs on the back of it.
Good luck mate, I removed one of these to try and cure a faulty fuel gauge and failed even though I am a wizz with an iron :shrug: Personally I think my brothers intermittent fuel gauge was a problem with one of the chips in the cluster as aposed to a dry solder joint, I must have resoldered every possible joint.
Let us know if you fix it.
130 ibiza
Cheers lads! I'm going to give it a bash hopefully on Saturday.... I'll let you know how I do.....
SWANSWAY CUPRA Dealership
