hey stu got my callipers back today and think they did exactly what and where the machining was meant to be done: (?)
cheers
Bit of an update with Cadwell Park track day looming:)
The strutbrace had become bit of saga, twice i went to collect it and it was not ready and when I did the monkeys had bent it and even painted it:no: still at least it matches the rockercover now:)
Coilpack mounted to the strutbrace rather than to the engine itself after the previous bracket had failed
Bought these fancy balljoint extenders, they help keep the wishbones level with a lowered car and the geometry or somthing..... will also help when I get the brake cooling shrouds on when i rout the flexible housing under the driveshafts
Also chucked on a new set of DS3000 pads and grooved discs and only a few bits remaining till its ready for Cadwell:)
Have you looked into it yet ?? can do a diagnostic check on it at the weekend if that's any help
Not plugged in the vagcom yet, somthing is definetly amiss as I was sitting stationary at some lights with my foot on the brake then felt the abs pump activate and then the light came on:shrug:
Nice work stu, what are the DS3000's like on the road?
PS. im getting my tyres fitted at Unit 3 on monday midday, so i'll wave to you if your at work lol
