so does the k04 mani and turbo just bolt straight onto the engine? then just need to change the oil inlet and outlet lines and mapping? oh and the dp too......
I dont no just to go past me
I didn't need it at Lydden :cartman:, i wasn't going to do it but you know what im like when i get an idea mate :whistle:
It bolts to the head okay but everything moves over to the right (as you look at the engine, a bit more) this is where it's getting interesting on mine, the tip is now directly where the heater pipes are so im reworking them at present, dp is spot on but my centre pipe is about 3" short of meeting it so will need extending, im just taking my time with it and trying to do it all right so im happy with it
The parts i got from Alex were
K04 & manifold
All the oil and coolant lines
Charge pipe
Tip
ECU with map
Uprated injectors
DP and de cat pipe
Extra's i've needed so far are 3" maf and a new air filter, various gaskets and washers and a few bits of pipe, there's deffinatly going to be more as i go though
Ive said it before but I will definetely say it again, ur car is amazing!!
Will be even more impressive with the ko4 turbo and manifold. I would love to see this in the flesh.
Cheers, it's mainly at track days you'll see me with it as that's what i use it for, although i do go to the odd show every now and again
love this car, we'll have to meet up at some point roly and have a compare, although yours is much higher specced than mine
It won't be on the road for the next kent meet but im sure once it's done i'll be getting out and about in it a bit more
Well things have kind of come to a halt due to requiring more silicon hose that i don't have
The DP is now bolted on along with the egt and wide band lambda sensor, the wiring is through the firewall and inside the car ready for pluging in.
I decided while i was waiting for parts for the engine i may aswell pull the dash out ready to replace it with my new one (reason for this is the holes i cut for the cage were a bit messy) i also set about the cupra R pillar pod adding an extra hole so i could get my new vems gauge in there
Tomorrow i'll hopefully have the dash back in and the gauges all re-wired, then it's just a matter of waiting for the next delivery of bits
Oil cooler looks the nuts!! Gauge should look spot on there too!
I'll try and pop up next week to keep you company.
wow, looks like fun, good work there roly
Dashboard has been out nearly as much as the engine, it's getting easy to do now
My god that car is in bits again
You wait till we set about your car mate ;)
Im well happy with the gauge fitment, i should know by tuesday what pipework i need so we'll get that order in then
you were busy after i left,you still had a dash last i saw.gauge looks good mate.nice to see you got the legendary blanket in the pic ha ha.thanks again for ya help yesterday mate
looking good mate!in the pic were the dash is out,in the middle there is paint missing on the dash,is that were you had to his hit it with a hammer to make the dash fit?
Dash was a last minute decission, gave me a head start today though which was good, no probs with doing yours mate gave me a break from mine, soz about last night aswell
this is one stunning car!
can i ask how much you paid for the cupra r gauge pod roly?
I brought a complete accessory centre console on flebay but the gauge holder is about a tenner from the main dealer
That was where the sound deadening was stuck on and i took it off (there's no paint missing just the sticky stuff off the sound deadening that didn't come off) you don't have to beat anything to make the dash fit, it's just the top A pillar brackets that don't line up
