N249 Bypass guide LCR
mattdavies
Pre-Facelift Bumpers FTW
Jan 24, 2009
88
Maidenhead
just did this on my stock LC and def feels faster. i used the other guide forthe cupra and for afew quid and 20mins one the best things i have done so far. No fault codes either :)
qed296
Leaving it standard
Jul 19, 2009
97
Leon Cupra R 225
Just done mine.Seems to be worth the £1.20 it cost me !!! The standard DV even let's off a little now.
Me thinks a 007 jobbie is next......so much for leavin standard(if i had a pound every time i've said that)
B3LSY
just did mine and you get abit of chatty not alot but need to give it a blast later
J0N
Defected!
It's not a loud jap chatty,I'll see how it runs for a few days
Don't get me wrong it's not the sound that I've got a problem with, in fact it can sound pretty cool. It's just I've always though wastgate chatter was a bad thing causing excess stress on the turbo. I'm not 100% certain on this btw and I'm happy to be corrected.
I robbed this off Wikipedia;
"Wastegate chatter myth
There is confusion in the automotive world about so called "wastegate chatter" or "turbo flutter". A noise created on lifting off the throttle in a turbocharged car, commonly described as a chipmunk or a rattlesnake, is often stated incorrectly as being a result of the turbo's wastegate closing.
The noise is in fact the air compressed by the turbo passing back through the compressor wheel of the turbo after the airflow is abruptly halted by the throttle plate closing, called compressor surge. However, in some cases, i.e. where the throttle plate doesn't open fast enough or is set up to only react to high boost, some chatter will remain. Surge can occur on diesels when the turbo is attempting to pressurize the air at a higher pressure ratio than the compressor wheel can flow at a given speed. Diesel engines have no use for a blow off valve as they do not have a throttle plate.
The chatter noise is very noticeable on World Rally Cars, where anti-lag is used.
A compressor stall like this can cause excess stress and wear on the turbo's shaft or bearings under higher load applications of the turbo (around 15psi and greater depending on the trim and flow rate of the compressor side).
Actual wastegate flutter occurs instead under partial boost conditions such as partial throttle near the boost threshold. It sounds like FftFftFft not ShuShuShu and is caused by the rapid opening and closing of the wastegate at boost levels near the spring pressure. It is commonly heard more clearly and may be more prominent on cars with modified intake silencers, up-pipes, and or downpipes, and is not harmful."
B3LSY
i put mine back to standard as this morning it sounded like it was struggling for air
dg-1984
254
Glasgow'ish
Ebay CLICKY
I got mine from them but think I may have went for the 3mm-4mm reducer as one of the pipes was smaller I am not 100% sure on that though, worth checking pipe ID to make sure will fit.
dg-1984
254
Glasgow'ish
The pipe's you have removed had internal connections into the anyway, when they were fitted onto the N249.
I didn't notice any problems with it.
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
i think i've read too much
I thought i had it sorted but this guide is saying you dont need a T piece
Are there 2 ways to do this mod (one with T piece and one just hose joiner)?
Are the 2 methods for different engines? (i have LCR)
