Upper green goes to red on sender, upper black goes to black on sender. Upper red goes to yellow fusebox screw 75xx or something under the lower dash trim as it needs 12v supply, not 5-9v variable from dmmer switch or you'll be able to alter the temp yourself. The wiring diagram was wrong n mine and i had 2 wires going to sender instead of just the one. You need to check your sender.
