how do i do that bill.... via unisettings?
thanks
Group A: '003 Group B: '115 Group C: '020
Engine Speed Intake Air Mass Throttle Drive Ignition Engine Speed Engine Load Charge Pressure Charge Pressure Cylinder 1 Ignition Cylinder 2 Ignition Cylinder 3 Ignition Cylinder 4 Ignition
TIME Angle Sensor 1 Timing Angle TIME (specified Value) (actual Value) TIME Angle Delay Angle Delay Angle Delay Angle Delay
STAMP /min g/s % °BTDC STAMP /min % mbar mbar STAMP °KW °KW °KW °KW
0.3 2600 65.42 97.6 19.5 0.61 2720 130.8 1750 1740 0.01 0 0 0 0
1.21 3000 79.53 100 9.8 1.51 3120 140.6 1840 1770 0.91 0 3 3 6
2.11 3400 106.08 100 8.3 2.42 3520 169.2 2060 2130 1.81 0 3 3 6
3.02 3840 113.78 31.8 11.3 3.32 3960 123.3 1560 1650 2.72 0 2.3 2.3 5.3
3.93 4200 121.75 98 18.8 4.23 4320 169.9 2030 2140 3.62 3 2.3 2.3 5.3
4.83 4680 162.06 100 9 5.13 4840 178.9 2060 2210 4.53 3 5.3 8.3 5.3
5.75 5120 170.78 100 12.8 6.04 5280 173.7 2050 2090 5.44 6 5.3 8.3 4.5
6.64 5560 175.94 100 9.8 6.95 5680 162.4 2020 1990 6.34 6 8.3 8.3 4.5
7.56 5920 173.78 100 8.3 7.86 6000 154.1 1980 1910 7.25 5.3 8.3 7.5 3.8
8.45 6200 175.69 100 9 8.75 6280 147.4 1900 1840 8.16 5.3 7.5 7.5 3.8
9.37 6440 171.86 100 16.5 9.66 6520 138.3 1840 1780 9.06 4.5 7.5 6.8 3.8
Group C: '020
0.28 0 0 0 0
0.58 0 0 0 0
0.88 0 0 3 3
1.18 0 0 3 3
1.49 0 0 3 3
1.79 0 0 3 3
2.09 3 0 3 3
2.39 3 3 3 3
2.69 3 3 3 3
2.99 3 3 3 3
3.31 3 3 3 3
3.6 3 3 3 3
3.9 3 6 6 6
4.21 3 6 6 6
4.5 3 6 6 6
4.81 3 6 6 6
5.11 3 6 6 6
5.41 3 6 6 6
5.71 2.3 6 6 6
6.02 2.3 6 6 6
6.32 2.3 5.3 5.3 5.3
6.62 2.3 5.3 5.3 5.3
6.93 2.3 5.3 5.3 5.3
7.22 2.3 5.3 5.3 5.3
7.53 2.3 5.3 5.3 5.3
7.83 2.3 5.3 5.3 5.3
8.13 2.3 5.3 5.3 5.3
8.43 1.5 4.5 4.5 4.5
8.74 1.5 4.5 4.5 4.5
9.04 1.5 4.5 4.5 4.5
9.34 1.5 4.5 4.5 4.5
Group A: '003 Group B: '118 Group C: '031
Engine Speed Intake Air Mass Throttle Drive Ignition Engine Speed Intake Air Charge Pressure Charge Pressure Lambda Sensor Lambda Sensor Bin. Bits
TIME Angle Sensor 1 Timing Angle TIME Temperature Solenoid Valve (actual Value) TIME Current Value Specified Value
STAMP /min g/s % °BTDC STAMP /min °C % mbar STAMP
0.6 2760 76.92 100 14.3 0.01 2520 20 0 1050 0.3 0.914 1
1.51 3240 117.17 100 7.5 0.91 2920 21 86.3 2050 1.21 0.992 1
2.42 3760 138.22 100 3.8 1.81 3440 23 81.2 2350 2.11 0.953 0.953
3.32 4280 147.78 100 6.8 2.72 3920 24 82.7 2410 3.02 0.93 0.945
4.24 4800 161.86 100 9 3.62 4440 27 82.7 2310 3.92 0.891 0.906
5.13 5240 174.31 99.6 7.5 4.54 4920 30 83.1 2210 4.83 0.899 0.899
6.05 5640 175.69 100 9 5.43 5360 33 83.5 2090 5.73 0.883 0.883
6.95 6000 177.61 100 8.3 6.35 5760 36 84.3 2000 6.64 0.883 0.875
7.86 6280 173.75 100 12 7.25 6080 38 82.7 1940 7.55 0.867 0.883
Is yours narrow or wide band lambda?
could it be a lambda problem? no fault codes present.
Group A: '003 Group B: '020
RPM Mass Flow Load Ign. Timing Degrees Degrees Degrees Degrees
TSTAMP RPM g/s % ° TSTAMP CF CF CF CF
0 1280 7.67 5.9 27.8 B 0.58 0 0 0 3
1.22 1120 8.06 6.3 23.3 B 2.19 0 0 0 3
2.82 2040 35.42 86.7 18.0 B 3.41 0 0 0 0
4.02 1920 5.36 3.9 7.5 B 4.61 0 0 0 0
5.22 1200 6.89 5.5 28.5 B 5.85 0 0 0 0
6.81 880 13.7 36.9 8.3 B 7.46 0 3 0 3
8.45 1120 18.22 49.8 1.5 B 9.03 0 2.3 0 2.3
9.66 1280 22.64 60 6.8 B 10.65 0 3 0 0
11.27 1520 29.39 71 9.8 B 12.28 0 3 3 0
13.27 1920 41.22 86.7 10.5 B 13.88 0 3 0 0
14.5 2200 59.7 94.1 9.0 B 15.47 0 2.3 3 6
16.1 2720 114.5 100 1.5 A 17.1 0 1.5 2.3 5.3
18.1 3480 129.44 100 4.5 B 18.74 0 1.5 2.3 4.5
19.71 4080 152.47 100 6.8 B 20.32 3 3.8 3.8 3
21.35 4680 178.72 100 8.3 B 22.38 8.3 6 6.8 5.3
23.34 5320 187.47 100 8.3 B 23.97 8.3 9 6 4.5
24.96 5720 194.44 100 6.8 B 25.95 7.5 8.3 9 4.5
26.59 6000 198.11 44.7 5.3 A 27.6 0 0 0 0
0 800 3.56 2.4 3.0 B 0.61 0 0 0 0
1.22 760 3.58 2.4 5.3 B 1.8 0 0 0 0
2.44 760 3.5 2.4 4.5 B 3.02 0 0 0 0
3.64 800 3.5 2.4 2.3 B 4.23 0 0 0 0
4.84 1600 23.86 59.2 14.3 B 5.45 0 0 0 0
6.07 1400 18.36 12.9 19.5 B 7.04 0 0 0 0
7.68 2360 39.58 23.9 23.3 B 8.66 0 0 0 0
9.27 3360 5.81 5.5 1.5 A 9.86 0 0 0 0
10.49 1640 14.03 9.4 27.0 B 11.49 0 0 0 0
12.1 1880 36.45 85.5 12.0 B 12.7 0 0 0 0
13.31 2280 59 94.9 10.5 B 14.29 0 0 0 0
14.92 3120 127.03 100 3.0 B 15.51 0 3 0 0
16.1 3920 146.97 100 6.0 B 16.71 0 3 0 0
17.33 4640 176.61 100 9.0 B 18.33 3 2.3 3 3
18.94 5560 189.97 100 12.0 B 19.54 3 0.8 2.3 2.3
20.14 6080 198.42 99.6 12.0 B 20.75 2.3 0.8 2.3 2.3
21.34 6520 199.72 100 15.8 B 21.93 2.3 0 1.5 1.5
22.56 5600 9.22 9 5.3 B 23.16 0 0 0 0
Marker STAMP /min g/s % °BTDC STAMP /min % mbar mbar STAMP °KW °KW °KW °KW
0.01 2640 30.28 18.4 26.3 0.25 2720 89.5 1570 1210 0.56 0 0 3 0
0.86 2960 88.5 100 11.3 1.16 3080 163.2 2140 2070 1.46 0 0 3 3
1.76 3440 111.69 100 7.5 2.06 3600 161.7 2080 2080 2.37 0 0 3 3
2.67 3920 127.61 100 9 2.97 4080 163.9 2110 2140 3.27 0 0 2.3 3
3.57 4400 144.03 100 9.8 3.88 4600 172.9 2020 2080 4.18 3 3 2.3 2.3
4.48 4920 159.28 100 10.5 4.78 5040 169.9 2050 2040 5.08 3 6 5.3 5.3
5.38 5360 168.89 100 10.5 5.7 5520 163.2 2050 1980 5.99 2.3 6 5.3 5.3
6.29 5760 175.14 100 11.3 6.6 5880 157.9 2000 1890 6.89 2.3 5.3 4.5 4.5
7.21 6120 172.69 100 9.8 7.5 6200 146.6 1930 1860 7.81 2.3 5.3 4.5 4.5
8.11 6400 171.61 100 14.3 8.41 6480 132.3 1830 1710 8.71 1.5 4.5 3.8 3.8
Saturday 6 February 2010 08:40:27
06A 906 032 HN 1.8L R4/5VT 0002
Engine Speed Intake Air Mass Throttle Drive Ignition Engine Speed Intake Air Charge Pressure Charge Pressure Lambda Sensor Lambda Sensor Bin. Bits Bin. Bits
Marker STAMP /min g/s % °BTDC STAMP /min °C % mbar STAMP
0.25 2440 35.56 21.2 23.3 0.55 2520 15 9.8 1250 0.02 0.984 1
1.16 2720 68.89 99.2 18.8 1.46 2880 13 74.1 1700 0.86 0.945 1
2.06 3160 84.92 100 13.5 2.36 3280 12 75.7 1860 1.76 1 1
2.97 3600 105.94 100 12 3.27 3760 12 84.7 2110 2.67 0.984 1
3.87 4080 131.72 100 14.3 4.18 4280 12 83.5 2130 3.57 1 1
4.78 4600 150.33 100 11.3 5.08 4760 14 84.7 2100 4.48 0.953 0.969
5.68 5080 164.69 100 10.5 5.98 5240 15 85.9 2040 5.38 0.914 0.922
6.6 5520 168.08 100 11.3 6.89 5640 17 85.9 1910 6.3 0.906 0.906
7.5 5880 172.14 100 12 7.81 5960 18 86.3 1790 7.2 0.883 0.899
8.4 6160 168.11 100 14.3 8.71 6240 19 81.6 1800 8.1 0.906 0.906
9.3 6400 167.81 100 16.5 9.62 6520 20 78.4 1660 9.01 0.891 0.906
10.22 6680 152.64 100 23.3 10.52 6720 20 78.4 1610 9.92 0.945 0.945
