No Drive after thud from front end, something gearbox but not sure, help!
elviscat
259
Bristol, UK
Hi all,
LCR 05 Cupra R, 133000miles, BAM engine, 02M front part of part number underneath box.
Driving along no more than 30mph, not changing gear, just chilled driving. Heard a thud from the front end through the car, i dipped the clutch straight away, checked the engine was ok. but when i brought the clutch pedal up no drive. I coasted to the kerb. Clutch pedal works as normal, I can select gears, but when i bring the clutch pedal to bite, the engine tone dips as the friction plate grabs but no movement. Had to be towed back on a bar, driveshafts are fine and running fine, diff is working fine as went around bends roundabouts etc no problem. No oil leak, no smell, no holes in cast, no rattling or random sounds at any point aside from the thud.
I've disconnected everything and loosened gearbox bolts and it's ready to get out tomorrow, drive shafts all ok.
I don't know what to expect if it was DMF failure, does this sound like DMF failure as what i've read is more rattling when DMF fails! how will I know if the DMF has failed in comparison to the new one, and would this cause these symptoms?
Can anyone suggest what else to look or test for? Any ideas, or suggestions, or if anyone has been something that sounds similar ?
Manic172
Dec 4, 2018
1,269
1,297
Hemel hempstead
www.seatcupra.net
DMF start to rattle then fail.. as Thai says sound like clutch failure... I would more go towards clutch plate expoding. I never seen a pressure plate fail. Only loose pressure due to over heating . Can't be bearing as it would still drive . Am interested in the answers when you pull it apart
elviscat
259
Bristol, UK
Thanks for the replies, I forgot to ask can anyone recommend a clutch alignment tool that works with these, preferably something i might be able to get hold of tomorrow!
(if I'm lucky)
Manic172
Dec 4, 2018
1,269
1,297
Hemel hempstead
www.seatcupra.net
Halfords or your local car spares shoo will sell one.
Very easy to use and sold every where.
Reactions: elviscat
Rich.T
1,609
932
Or do it by eye. Lightly tighten 3 (at say12,4,and 8 oclock positions)of the bolts so the cover slightly grabs the friction plate. Then move the centre plate to the central point with a long 3/8 extension or long screwdriver.
Good to go.
DMFs fail but never heard of one lose drive altogether. Usually just cause clutch pedal and or cabin shake/vibration.
Alexis27
2,104
455
Manchester
If you're on 133k and your original clutch and DMF you've done well.
They can go at any time, even just tootling at 20mph. Usually clutch goes first, but you'll need a new DMF anyway.
I hope you have £850!
elviscat
259
Bristol, UK
Looks like Differential is in bits, took off one of the driveshaft flanges to get the box out, and by the time the box was out there was nothing for the allen key bolt to go back into through the flange, looking into the diff there seems to be some bits rolling around on their own.!! a mate is saying my as well get a recon box.
Any recommends?
elviscat
259
Bristol, UK
DMF and clutch are ok btw, although i have new ones to replace. I was thinking of getting quotes of Gloucester Road Gearboxes for a rebuild, any thoughts?
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,199
1,038
Kent
Thai might have a box laying about. He breaks a lot of leons
I don't have any out at the moment unfortunately.
I'm getting another LCR in for breaking tomorrow as it happens but too busy to do anything with it for a little while.
Sent from my SM-G986B using Tapatalk
Nizza
380
234
No but can source one if needed?
Sent from my SM-G988B using Tapatalk
