Online worksop manuel or not?
james_mk
Mk bandit
May 14, 2004
241
milton keynes/coventry
Can you download like a pdf file for a workshop manuel for the ibiza gti 8v.... im changing the head gasket etc etc and i need details, i.e valve timing, amount of torque needed etc and how to remove head etc. Unless anyones done it before and can give me all the detials....that would be great.. cant be asked paying 20 for a haynes manuel im a tight student.
cheers peeps.
james_mk
Mk bandit
May 14, 2004
241
cant you find me a free one.... or someone must know all the detials on here... that they can paste me......
the road in my sig...is up in coventry i belive...the road that goes towards birmingham... i dunno im a student there
ibiza_95
1.8T MK2 Conversion
what do you study at coventry? my brothers there doing an automotive course...
id scan my haynes but its several pages.
in a nutshell
drain oil
drain coolant, by taking the top and bottom hoses off the radiator
take all electrical connections off the head, as well as removing the air box.
unbolt the water pipe at the front of the engine,
take water pipe off the side
take accelerator cable off
unbolt exhaust manifold at a point behind the engine... (right arse... will probably take you all day to do this bit... getting it back on is easy enough.)
unbolt rocker cover,
unbolt head in sequence something like
______________________________
[ 1 7 9 5 3 ]
[ 4 6 10 8 2 ]
[_____________________________]
pull old head away
clean away old gasket and carbon off the head and block
new gasket on
(replace head bolts
tighten head on in opposite of undo sequence
ill get torque figures for tightening if you need them
new gasket and bolts will cost you 20 pounds from ECP
bit vague but general idea
Oh well guess my idea for a drawing didnt work then
james_mk
Mk bandit
May 14, 2004
241
tut indeed! well a mates helping me do all this..hes done it before but told me he needs to know the amount of torque or somin and valve timin..i dunno apparently its in the manuel...the haynes you have.,... isit just for the 2.08v gti...
What is the engine doing on your drive..... going in your beeza?
ibiza_95
1.8T MK2 Conversion
hmmmm
heres what haynes has to say
Torque settings
Engine codes AAU, AAV, ABD, ABU, AEX, APQ, AEE, ALM, AFT, 1F, 2E, AGG, ABF.
Stage 1 setting............................ 40Nm
Stage 2 setting............................ 60Nm
Stage 3 setting............................ Angle Tighten through 90'
Stage 4 setting............................ Angle Tighten through further 90'
Engine code AER
Stage 1 setting............................ 30Nm
Stage 2 setting............................ Angle Tighten through 90'
Stage 3 setting............................ Angle Tighten through further 90'
james_mk
Mk bandit
May 14, 2004
241
wel i was...then the head went...so..i might sell it once the heads fixed...but i dunno...its starting too look well sexy... ill see what offeres i get, but not in any hurry to sell.
hopkinsgm
Do-doo-be-do-do-dooo
May 25, 2001
2,030
Swindon (occasionally)
james_mk said:
OH man....engine code i have nooooo idea....
its a 1997 2.08v gti cupra sport.....
Early 2.0 8v's are 2E, late 2.0 8v's are AGG. Yours being a '97 it *should* be an AGG but anything's possible around that time. If you have the service booklet, there should be a build sticker on the inside cover - it'll tell you on there. Or failing that, dig out your vehicle registration document (V5), it should tell you the engine number (which includes the code) on there. So you don't even need to lift the bonnet... :)
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
james_mk said:
Beaver. Do you wanna buy some 15mm spacers brand new in box with bolts... two of em? stretch your rears out??
shush.
How much you selling the spacers for mate?? would they fit a 99 2.0l 16v?
james_mk
Mk bandit
May 14, 2004
241
Yeah they will as long as its a 4x100 which im sure it is. Theyre £40 i belive, and theyre stil brand new in the box, ive only taken them out once. ID do them for £35 and for that id post them to you.
if u wanna sort details out add me on msn or pm me.
[email protected]
