Indeed...exactly what I was going to say next from the reading I been doing on it.Aaron, I suppose you've thoroughly checked the vac line to the FPR.?
Why would genesis scrub a number out. They don't use a Bosch injector do they???
You posted a link above Aaron to USRT, clink on the image of the Genesis 550's (it fills my screen) and compare (blue and green o rings). Looking at thoose logs i still don't feel you've been given the correct injectors. The revo software isn't at fault it can't be. If you can prove with a cheapo gauge that you have 3 bar of fuel pressure (i think you must add an extra bar for atmospheric) it must be the injectors. If you had a vac leak you would have rough idle and probably throw a fault code.
Your injector duty cycle is still too high for the 550's.
Having a look back on the usrt website it can be seen that Genesis also supply 315 and 380cc in black, there are suble differences though in the O ring colour and the angle and shape of the wiring connector. You should be able to identify your injector from exploding these images. If it transpires you have been given the wrong injector again, send them back for a refund and buy from someone else such as backdraft.
Can you not send them back and get refunded and then purcase them from elsewhere? Are these not brand new injectors that come in a nice sealed box? Sounds like you just getting abag full of them.
Just had a thought (remembered)
the long term trim is now -3%.... How can it be lean but showing rich. These injectors must be bigger than the 380cc as they were running at 25%??
Food for thought? Points to pump?
Tuesday 24 November 2009 18:20:51
1ML 906 032 A 1.8l R4/5VT 0001
Group A: '002 Group B: '032
RPM Load Inj. On Time Mass Flow Lambda Lambda
TIME TIME
MARKER STAMP /min % ms g/s STAMP % %
0.4 760 15.8 1.7 2.31 0.8 5.8 -3.9
1.21 760 15.8 1.7 2.31 1.61 5.8 -3.9
2.01 760 15.8 1.7 2.31 2.41 5.8 -3.9
2.81 760 15.8 1.7 2.31 3.21 5.8 -3.9
Yarp, in a bag Nick
I have someone elses now.
Wednesday 25 November 2009 21:57:23
Group A: '002 Group B: '031
RPM Load Inj. On Time Mass Flow Lambda Factor Lambda Factor
TIME TIME
23.57 3440 64.7 4.42 45.47 23.17 0.977 0.992 12.67066667
24.37 3520 65.4 4.42 44.44 23.97 1 0.992 12.96533333
25.19 3560 70.7 4.76 48.67 24.77 0.992 0.992 14.12133333
25.99 3600 76.7 5.44 54.64 25.59 0.984 0.977 16.32
26.79 3680 75.2 5.1 51.53 26.39 0.953 0.961 15.64
27.59 3760 74.4 5.1 53.31 27.19 0.961 0.961 15.98
28.4 3840 84.2 6.12 64.31 28 0.945 0.945 19.584
29.2 3960 103.8 7.82 83.56 28.8 0.922 0.93 25.806
30 4200 191.7 15.64 175.44 29.6 0.821 0.821 54.74
30.82 4640 191.7 20.06 217.58 30.4 0.821 0.797 77.56533333
31.62 4960 191.7 19.72 213.81 31.22 0.774 0.797 81.50933333
32.42 5280 191.7 20.4 225.72 32.02 0.75 0.665 89.76
33.22 5600 191.7 20.4 235.94 32.82 0.75 0.68 95.2
34.04 5880 191.7 19.38 244.92 33.64 0.75 0.696 94.962
34.84 6160 191.7 18.36 251.06 34.44 0.75 0.68 94.248
35.64 6360 191.7 18.36 260.86 35.25 0.75 0.727 97.308
36.45 6600 191.7 19.04 260.86 36.05 0.75 0.688 104.72
37.25 6800 191.7 18.02 264.47 36.85 0.75 0.704 102.1133333
