Hi Guest we, are working on an upgrade to the forum this week, meaning the service may be unreliable at times and there will be some planned downtime at some point. Stay updated on this thread.
i find that you put the front side in first then have to push and pull at back of cover under car and tap it in or use a rubber mallet which works well
I've found the top edge is lipped so feed that into the skirt and then just push the cover back into postion and with a firm smack with you hand they should stick
Okay this might be a stupid question but you do realise the front and rear are different?
They are a PITA
I found a flat blade screwdriver helped also getting the car lifted a bit so you can give it a right smack
now they're on i do not remove! brought a lower lift point jack and use two blocks of wood for the front just to avoid taking them off! worst designed part on the car! lol
had a similiar problem with mine when the young geezer took one off to get his jack underneath the car. When it came to putting it back on it was a total nightmare. However as I was paly with the local dealer I took it to them and they fitted it straight away. You would have thought they would improve on such items, some things bever change i guess.
