Removing Brembo's, Update, refurb finshed, pic's inside
Aug 1, 2009
511
Hemel Hempstead
Man - I seriously need to have a go at this over the summer - for such a small thing, they just stand out so much and look ace when done up again... Time to start buying up decals :)
rsmith
Robbie
Apr 28, 2004
2,796
Tipperary, Ireland
ok, done. In the process I noticed on the left side the rotor was much more worn on the inside while the right side it was worn even. What would cause this? Air bubbles?
Also I found out while bleeding the brakes that dot 4 fluid really eats paint, so in the end I probably have to do all over again...
Turbin, there is nothing wrong with them, from your description i thought you made a right bollix of if it, they look good.
turbin
not really.. the left side got hosed in brake fluid and while I wiped that away I also took off half the layer of clearcoat.. When I get motivated Ill sand it down a mm and clear it again a couple times.
rsmith
Robbie
Apr 28, 2004
2,796
Tipperary, Ireland
Brake fluid is nasty stuff, it does not mix well with paint at all.But at least you know what you are in for next time round.
