any pics on the fmic spray mod ????
Havent taken any pics sorry, not much in it really, jsut a 4mm vac hose running from the original rear washer pipe by the washer tank which runs to me fmic and then runs from over the top and at the bottom and have used a pin to make some holes in it so it sprays all over the cooler, doesnt do much tbh, may be 2/3' cooler in warm weather... havent tried it in cold weather.
which hose is the one coming from the washer bottle pls?
If you look at the pump at the side of the washer bottle you will see 2 pipes coming from it, follow one to see if it goes to the front or back so you can identify which one is the rear washer pipe... i just disconnected the the pipe at the coupler and connected my new pipe onto it,
