Poverty
As said above, I have sprayed quite a lot of plastic parts and ensure you "key" the surface with some high grit (600 or so) wet and dry paper so the primer can take to the shiney surface. Also ensure when you are buying primer that you buy plastic primer as it's what you need, 3-4 coats of colour with wet and dry 800 grit between coats to ensure a smooth reflective finish then a couple of coats of lacquer will do the job nicely
Clarke
Top man, I gonna be giving it a shot myself soon!
