RR results from AMD Essex RR Day 22/02
Jun 29, 2001
537
Surrey
Here's the printout for my K03S Ibiza at the RR day at AMD today.
Mods as follows.........
K03S with 4bar fpr
Forge FMIC
3" Z-Ex Downpipe/100cel cat into 2.5" Scorpion exhaust
CAI kit
Jabbasport remap + boost controller
Forge DV007P
Forge TIP
EVOshield inlet manifold gasket
N249 removal
Stage 2+ clutch with lightened flywheel
Test 1 = 249.6 hp at 5035rpm
308.9 lb/ft at 3605rpm
Test 2 = 250.2 hp at 5035rpm
306.7 lb/ft at 3535rpm
As you can guess, I'm quite pleased with the result as some of the standard cars that also ran were putting out pretty much spot on book figures providing a good benchmark, plus my cars also done near on 120,000 miles.
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
2.0 16v ABF
Badger 5 Jenvey 45mm DTH Throttlebodie conversion
DTA ECU & custom map
Coilpack ignition
Ford based crank trigger
Magnecor 8.5 HT leads
RS Turbo spark plugs
F2 Stu custom made Airbox housing 90mm airhorns and custom made ITG filter element
1.8T fuel rail & injectors
288 duration cams
Supertech Stainless one peice valves, heavy duty valve springs & Titainium retaining caps
Ported and polished cylinder head (std injector ports filled in)
Wossner 13.4:1 forged pistons
Carillo H beam forged Con rods
Lightened & balenced crank
Lightened & balanced flywheel
Sachs Heavy duty clutch
Machined intermediate shaft
Windage tray
Shrick Baffeled sump
Custom made stainless 4-1 Manifold & de-cat
Jetex stainless Mk3 Cordoba cupra turbo 2.5" system
16 row oil cooler & thermostat controlled take off plate
2.0 8v AGG alternator & mounting brkt
Radtec custom made alloy radiator with WRC core & twin Spal fans
225 odd bhp @ 8000+ rpm :)
roly
midnightmotors.net
Jan 2, 2002
1,883
Midnight Motors Workshop
Here's mine
• JBS05 hybrid turbo
• Forge K04 actuator
• K04 exhaust manifold
• 4 bar fuel pump
• 386cc injectors
• Evoshield gasket
• Forge 200 series universal intercooler
• Custom intercooler pipe work
• Green cone filter
• Forge recirculating dump valve
• SFS intake pipe
• Q Peng downpipe and decat
• 2.5" scorpion cat back system
• Setrab Proline SLM oil cooler with braided lines
• Custom Code phase 3 remap
1st run 246.6bhp & 257.0 lb/ft
2nd run 241.1bhp & 259.1 lb/ft
EmDee
Omnishambolic
Okay, here's my printout dealio
I got 222 bhp, and 211 lb/ft which is just about bang on what she's meant to have, although I hope she'll ride up with wear as she's only done 17.5k miles and she does have a few mods:
forge 007 whooshy
milltek catback (resonated)
samco inlet hose (#I got hose#)
pipercross filter
So i was a bit disappointed. Maybe it's as simple as an oil change and some plugs?
And by the way, Stu you missed your orange wheels off your mod list...
borisvanhalen
FR is not a dirty word...
Feb 7, 2009
120
salisbury
FR 20vT - at AmD with jabba stage 1 and pipercross panel filter
started life with 180 bhp / 173 torque
at AmD produced 222.3bhp / 271.4 torque[B)]
thats a cool 42 horses and nearly 100 torques
have since added Forge DV, done some cosmetics and have a few engine/exhaust mods to consider
Russ_tdi
Newbie
Mar 8, 2006
106
1.9tdi
Started off with 130bhp
Mods....
Hybird Turbo
Ported inlet manifold
Ported exhaust maniflod
EGR Removed
Custom 60mm boost pipes
Seat sport FMIC
Full miltec exahust system
Water/Methanol Injection
SMF
Uprated clutch
ATB differential
Lots more carnt remember it all at the mo lol
Made 259bhp and 390lbft
Dont think double the standard horse power is to bad for a diesel:D
