scan results
LCRglen
86
colchester essex
update have checked the exhaust and found no air leaks , did find some rust and small holes in my backbox though , obviously wouldnt effect my running issues but just something else to replace .
LCRglen
86
colchester essex
fingers crossed ive finally found my problem ! oh if only . yes quite a bit of oil down there have checked the level and topped it back up reckon a bit of engine de gunking aswell is now on the list of to do's.
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
yea this will cause running problems and it will be drawing in un metered air. common prob on 1.8t
only a few quid so should be a cheap fix to you nightmare of problem
LCRglen
86
colchester essex
woooooooooohhhoooooooooo:):):D:D just changed dipstick tube and took her for a quick 15 minute drive .and missfire is gone . i lurve my leon again . guess what i am doing today now . driving ! its the first time in 3 monthes odd of ownership i can actually drive her properly :D:D:D . thanks everyone for all your help especially andy (s3 akr) any help you need give me a call .
S3 AKR
livin' the dream!!!
Jun 30, 2004
1,453
Colchester, Essex
Only just spotted this mate!!! Excellent news though - I said it'd be something stupid that was causing it! So....... when does it get the remap ??
LCRglen
86
colchester essex
hmmm problem resurfaced again bloomin car , can now add n249 bypass to things i have done aswell now to try eliminating the problem also got a new dump valve coming this week . soooooooooo all thats left to check now is .
1 . get lambda sensors checked at garage
2. strip back coil pack wiring and repair or reinsulate
3 . fit new spark plugs even though i know mine are fine .
and then number 4 if none of the above works drive at speed into a brick wall . lol
LCRglen
86
colchester essex
arghhhhhhhhhhh . right here is my thoughts . the car drives fine when started from cold allowed to heat upto normal temperature 90 . i can then floor it in any gear for about 4-6 times ,which gets some real heat in the engine it is then that the problem starts . or drive it normal and when left to idle for any long period . now when it idles the missfire has definately got worse and is constant . if i had an air leak surely this would affect it from cold and at all times , which makes me think pre cat lambda is the problem ? what do you think people ?
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
id be changing the fuel filter first... if youve checked for split hoses and cant find anything, then get a pressure test done to find the air leak.
have you checked fuel lines etc etc.
did you autoscan on vagcom for faults or just log?
james walker
May 24, 2007
5,121
retford notts
with you saying it pulls back from 4-6k... theres no timing pull there at all, according to the logs
id be getting a pressure test done, then change fuel filter... get a garage to get it up on ramps to check dp and cat for splits and lambda connection etc.
have you checked intercoolers and pipewrok to them... check the cooler themselves.
so to wrap up... either dodgy lambdas, split vac hose(major one somwhere) or dp and cat problem.
