SEAT Sport FMIC Diagram
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
where did you buy that pipe from renda??
its not all the same as before and shinyier as that restrictive plastic pipe has gone!
Renda
141
Zagreb, Croatia
I'm just kidding, ofcourse the airflow is better because of less restrictions and no bending of the rubber tubes under boost!;)
A friend of mine made the pipe, along with all the other pipes on the car...:)
air121005
1,609
Worcestershire
iirc, that sensor is on item 9 on the SMIC setup.
rash, couldn't you use item 9 from the SMIC setup and replace the restrictive item 8 with ali & silicone of your choice! ;)
had a look earlier and its not mounted in this pipe :confused:
it must have a location within the system, any body know where it is?
air121005
1,609
Worcestershire
does this mate, make this in a kit for fellow scn'rs ;)
i reckon there could be a few interested, looks well made imo :clap:
if the price was right, i'd be interested!
Rosco906
1,445
Burntisland, Scotland
Yes forge sell the kit for £234 including vat
If Rash can find the size's of everything u can find it all on ebay for cheaper
How much was the bracket (15) and the 2 bolts 19+26
rashcupra
Oct 15, 2006
6,517
crawley
im not at work till next wednesday so itl be a wait :) did take time off for driving around and getting used to power but its taking a bit longer than exspected :(
maxcars1
735
Ive got all the details on pipework as mine was the first car to use Foge pipework with the Seat Sport FMIC ;)
maxcars1
735
[/IMG]
there you go :)
maxcars1
735
what are the diameter sizes of the aliminium tubing, the silicone hoses and the reducers?
hoses are 51mm and reducers are 60-51 mm. Alloy pipework - You need x2 90 degree elbows of which one will have the MAP Sensor fitting on. You also need a 45 degree elbow. Pipework will be 51mm i think then.
air121005
1,609
Worcestershire
unless any of us are willing to buy the forge kit, then the sensor location is going to have to be made in the system.
already, got a few ideas ;)
the hole which the sensor fits into, what diameter is that?
or should i say, how big a hole does that sensor need to locate into?
