some ICE installation photo's & questions pls
Phil_beeza
461
does anyone know what this pink connector by the pedals does pls
and would anyone remove this inner door panel for dynamatting?
thanks !
Phil_beeza
461
oh one other thing, when im digging up the side trim at the drivers footwell, there is the bonnet catch, and the button to disable the ultrasonics.
any tips and tricks on how to remove this panel without disrupting that lot?
Bell_130
The connector is the OBD2 port for vagcom and the likes is it not? No idea about your other questions though! sorry!
Phil_beeza
461
oh, good to know.
so if i bought a vag.com pack, i would get a cable with that on one end and a serial on the other?
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Yes strip the door to dynamat if you want to sound proof.
Personally i'd check behind the scuttle panel before using the washer pipe grommet for a power cable. I think the Ibiza has the same grommets as the Fabia to route the power cable though (easily takes 4awg cable).
Take a look at the right hand side as you look at the engine bay.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
You have to undo the window from the regulator before it comes out so it either has to be up and secured or removed.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
You can secure the window up whilst working with some masking tape looped over the top of the door frame.
