Good god thats dirty - thought mine was bad but looked new compared to that!! Ok, if you have Vag Com or a Liquid Gauge you can do a throttle body re-set. I believe leaving the battery off overnight does it too! Reason being - you want to move the butterfly and clean all around and get rid of as much of that as poss!! id say take off the inlet mani too!!
Take it all off, clean with carb cleaner and put back on with a £2 paper gasket - part number on here somewhere. Move the butterfly GENTLY with fingers and hold open while cleaning, some people shove pens in, im not a fan!
Done - quick 5 min job and your car will purr!
Took a lot longer than 5 mins but its clean now, moved the butterfly like you said! Car's going to a garage on thursday so might ask if they can do a quick re alignment. Should it be ok just for general runs in the meantime tho?
Didn't take of the inlet mani. Sounds a bit complicated! It did look very dirty in there tho. Is it difficult to do?
LOL prob cuz urs was so dirty it took longer :p hahaha! just a few more bolts and itll come off - it wont run overly well with it all outa place, perhaps try the battery trick in the mean time?
Are they just on the back? Will i need a new gasket? what do i do with the injectors?
Mine went repeatedly into limp mode after taking off until I realigned using vagcom. Liquid gauge alignment didn't cut it.
anyone near me needing to use the liquid gauge to set the TB, just pm me. Based in East lancashire
Hi guys cleaned my throttle body tday and now cars running crap a mate plugged it into vag com but he didn't realign he just said it showed up that there was a leak he thinks there's a crack in the inlet manifold do use think it just needs realigned ? It's 1.6 16v bcb
Start with re allinging, when I had my LCR I made sure I did.
Did the gasket come off ok or did that look a bit past its best? Maybe that is causing a leak?
Gasket looked fine il Mabey check again tmrw yeh I just wonders why it would need realigned ado didn't remove the plug so why would it need done could u shed some light lol?
Not sure, I thought the same when I did mine. You are just putting back the same as before but it only takes a few seconds to align it.
Not totally sure on this but I've heard the car will align itself but apparently not as well as doing it with software
I did mine with a handheld fault code reader.
Def check the gasket, remember not to over tighten the screws in the throttle body, its really soft metal
Yeh that's what I said to the boy that had it on vag com but he didn't think that would do it , all I think.it needs is realig ned hopefully that will sort it out
