& re-reading your post those aren't the latest maps BTW 26/27 release 2610 are
Evident mib helper hasn't been updated
Thank you, I've downloaded the latest update from the given link. I then made a backup of my original Seat map SD card (or better: the genuine card with the CID but in the meantime updated map material over the years) and extracted it onto a fresh 3rd party SD card (correctly formatted, correct cluster size). It did NOT work, the card was rejected. So apparently the "NoCID" patch I applied when updating my software train in the MIB2 to fix the clock bug did not really work and I still need the original card.
I then deleted the "map" folder on the genuine card, unpacked the contents of the latest and greatest update et voila: Everything worked and I now have the latest map pack.
Thank you!
I still have a couple of questions if I may:
* Is the overall.nds tied to my VID/Serial of the unit or is it version specific? What's in the file?
* For applying the latest update, I did not need to copy over the overall.nds file from the last state of the genuine card, just used the one which got unzipped from the downloaded archive. Is that working because of the card being genuine and the CID serial number is used? The overall.nds file I had on my genuine card is probably long gone anyway during the various version updates. I never had to backup/restore that overall.nds file when doing an update so far. My Seat Alhambra is from 2016, so long before that lifelong FEC where applied if I understood correctly? All I did was copying over the maps folder all this years.
* If my genuine card is accepted, why does the overall.nds then matter at all?
* I didn't need to add any new FEC, so this is not always necessary? It seems to be a part many are struggling with according to this thread?
* I just checked my FECs, I don't seem to have the lifelong FEC 073000EE active nor available in the info menu I get when I press menu for 10+ seconds.
* In these yearly updates, is this just the map data or is there also a navigation software update included? Any functional changes?
* Where do I see the separate version of the navigation software if there's any? Are there any change logs of the software version?
* If software versions of the navigation system are NOT part of the map updates, where do I find those? Is it worth updating for my old car or won't recent version run on it anyhow?
Thank you!
Its linked to the original maps release release put in the unit. Say 2016/17 then any 2016/16 overall.nds file would work. Previously we had to find these releases which started to get tricky. Hence the overall solution of that one file.
Could be that the modification did work. Normally it doesn't work like that unless you were fortunate to have one of the 2019 units.
Ditto above
No the workaround creates the FeC that wasn't known originally. Hence the scan error that you get.
You will have something there. A Hex table can be used to work it out as I did with the mib2 high.
That's the map update. The software is the firmware and that doesn't need updating for the map update to work.
As above
As above
TMC UK Services mib2 standard and high
Just a note to say those that took steps to gain TMC services in the UK after Trafficmaster stopped transmitting the data three years ago (Vag provider and others) using the Inrix alternative provider... all has been good for more than three years with the Inrix service... however all good things come to an end, and this seems to be one of them.
Looking decidedly finished although there doesn't appear to be much mention of it online.The service was used by Jaguar Landrover and others. So it appears no more annotated delays marked up on your built in mib2 mapping system and alternative route, but if you didn't take steps to receive Inrix services, no change to how it's been.... that you have not been getting them. ;)
Following up on this now I am back in the UK. I can see that the RDS data groups that carry the TMC service are gone from both Wrotham and Dover Classic FM transmitters. They have separate feeds, so a fault at the transmitter sites looks unlikely. I guess the service has been withdrawn. I will try to find out more on Monday.
Reactions: Tell
Mib2 standard navigation release 2027. Version 2710
Eagle eyes via the Briskoda board have spotted the next map file release. Normal form will prevail the workaround to get these on a Seat.
New MST2 maps, 2027, 2710, V24:
EU V1: https://navigation-maps.volkswagen.com/vw-maps/Update_25_26/DiscoverMedia2_EU1_2710_V24.7z
EU V2: https://navigation-maps.volkswagen.com/vw-maps/Update_25_26/DiscoverMedia2_EU2_2710_V24.7z
EU V3: https://navigation-maps.volkswagen.com/vw-maps/Update_25_26/DiscoverMedia2_EU3_2710_V24.7z
EU V4: https://navigation-maps.volkswagen.com/vw-maps/Update_25_26/DiscoverMedia2_EU-DL1_2710_V24.7z
EU V5: https://navigation-maps.volkswagen.com/vw-maps/Update_25_26/DiscoverMedia2_EU-DL2_2710_V24.7z
EU V6: https://navigation-maps.volkswagen.com/vw-maps/Update_25_26/DiscoverMedia2_EU-DL3_2710_V24.7z
EU V7: https://navigation-maps.volkswagen.com/vw-maps/Update_25_26/DiscoverMedia2_EU-DL4_2710_V24.7z
EU Complete: https://navigation-maps.volkswagen.com/vw-maps/Update_25_26/DiscoverMedia2_EU-AS_2710_V24.7z
Thanks to Viper.
Xmas keeps coming early 🥰.
Do strictly follow the instructions if you have never done a mib2 standard map update on a Seat before. Instructions.... see below.
======= coverage =======
# ECE AS(A1) (All Europe)
Albania, Andorra, Austria, Belarus, Belgium, Bosnia and Herzegovina, Bulgaria, Croatia, Czech Republic, Cyprus, Denmark, Estonia, Finland, France, Faroe Islands, Germany, Gibraltar, Greece, Hungary, Iceland, Ireland, Ireland, Italy, Kosovo, Latvia, Liechtenstein, Lithuania, Luxembourg, Macedonia, Malta, Moldova, Monaco, Montenegro, Netherlands, Norway, Poland, Portugal, Romania, San Marino, Serbia, Slovakia, Slovenia, Spain, Sweden, Switzerland, Ukraine, United Kingdom, Vatican City State
# ECE 1
Andorra, Belgium, Faroe Islands, France, Gibraltar, Iceland, Ireland, Ireland, Luxembourg, Monaco, Netherlands, Portugal, Spain, United Kingdom
# ECE 2
Albania, Belarus, Bosnia and Herzegovina, Bulgaria, Cyprus, Denmark, Estonia, Finland, Greece, Kazakhstan, Kosovo, Latvia, Lithuania, Macedonia, Moldova, Montenegro, Norway, Romania, Russian Federation, Serbia, Sweden, Ukraine
# ECE 3
Austria, Croatia, Czech Republic, Germany, Hungary, Italy, Liechtenstein, Malta, Poland, San Marino, Slovakia, Slovenia, Switzerland, Vatican City State
# ECE 4
Andorra, Austria, Belgium, Croatia, Czech Republic, France, Germany, Hungary, Italy, Liechtenstein, Luxembourg, Malta, Monaco, Netherlands, Poland, San Marino, Slovakia, Slovenia, Switzerland, Vatican City State
# ECE 5
Andorra, Austria, Belgium, Croatia, Czech Republic, Faroe Islands (land-use only), France, Germany, Hungary, Iceland, Ireland, Italy, Liechtenstein, Luxembourg, Malta, Monaco, Netherlands, Poland, San Marino, Slovakia, Slovenia, Switzerland, United Kingdom (incl. Isle of Man), Vatican City State
# ECE 6
Andorra, Belgium, Denmark, Faroe Islands (land-use only), Finland, France, Germany, Iceland, Ireland, Luxembourg, Monaco, Netherlands, Norway, Sweden, United Kingdom (incl. Isle of Man)
# ECE 7
Albania, Austria, Belarus, Bosnia and Herzegovina, Bulgaria, Croatia, Cyprus, Czech Republic, Estonia, Greece, Hungary, Italy, Kosovo, Latvia, Lithuania, Liechtenstein, Macedonia, F.Y.R.O., Malta, Moldova, Montenegro, Poland, Romania, San Marino, Serbia, Slovakia, Slovenia, Switzerland, Turkey, Ukraine, Vatican City State
ROW is yet to be released but for completeness:
# ROW 1
Israel, Argentina, Brazil, Fr. Guyana *, Guadeloupe *, Martinique *, Mexico, Turkey *
# ROW 2
India *, Chile *
# ROW 3
Australia, New Zealand, Botswana *, Lesotho *, Mozambique *, Namibia *, South Africa, Swaziland *; Reunion *, Brunei, Indonesia *, Malaysia *, Philippines *, Singapore, Thailand, Egypt *, Algeria *, Bahrain *, Jordan *, Qatar *, Kuwait, Morocco, Oman *, Saudi Arbien *, Tunisia, United Arab Emirates *
# MRM DL1
Argentina, Brazil, Mexico, French Guiana, Guadeloupe, Martinique
# MRM DL2
Israel, Turkey
The all important workaround is here
Workaround
Using a PC or a MAC ?
PC: 7 Zip is the preferred VW tool, other unzip tool including those built into Windows, can cause difficulties.
7 zip can be obtained from
https://www.7-zip.org/download.html
MAC: VW instructions
"ATTENTION
If the map update is performed using the Apple® OS X operating system you may find that
Discover Media does not recognise the map material or displays it incorrectly. This is due to
a lack of compatibility between the “7 zip” program and the OS-X operating system. In
addition, the OS-X operating system has a tendency to create hidden additional files on
external data media. We therefore recommend that OS X users use the “Keka” unzipping
program. We also recommend using the “CleanMyDrive” program to remove any hidden files."
If a MAC is used CleanMyDrive is run against the SD card after the maps are copied across to the SD card.
Having identified which unzipping tool is required and special Mac SD card cleaning required... free to proceed.
Steps:
  1. Download the latest standard MIB2 maps
  2. on the infotainment go to settings, safely remove, sd1 card
  3. remove sd1 card from glove box slot
  4. long press on the on / off to reboot it a couple of times
  5. insert sd card in to computer
  6. copy and paste all contents to a directory on your computer
  7. Delete the contents of the SD card, (don't forget to push the card lock mechanism to off) (ditto in a MAC) (don't do a reformat of the card)
  8. Copy the new downloaded map version to the SD card (after unzipping it)
  9. Replace /maps/EEC/EEC_WLD/OVERALL.NDS on the SD CARD with the one from the original SD card
  10. eject the sd card (on a MAC run CleanMyDrive on the SD card - then eject), click to lock
  11. Inserted the card into the card 1 slot in glove box whilst infotainment is off
  12. power on and go to navigation
The unit should then boot up into navigation. Note it does take a little longer first time round. If it refuses to boot up, press the volume button forcing a reboot, hold down until the unit reboots. If this fails it will be issues on the overall.nds file / copy issues. Revisit the process. Failing this restore the back up.
You will also need to pick up any POIs that you show on the screen since these will be dropped after a map update. Petrol stations, parking location etc.
Do not format the card in anything other than Fat32. The unit runs QNX so will not correctly see the SD card if it is not in Fat32 / cluster size gets tinkered with in a reformat. The CID is not deleted in a format that is outside of the area that can be addressed but reformatting has been known to corrupt the card.
If you do lose the NDF file then it's in the resource of how to sort it out. Read that under lost and stolen section:
It's this file attached is the fix all
Success screen. June 2026:
How to dig yourself out of a hole if you ignore the instructions for Seat is in that link. See also the resource for further details.
Xmas comes early. Mib2 high navigation files which covers Seat as well. File 470. 450 release Seat got dropped and you needed a Skoda or Audi FeC. Now its back in for this release.
Following eagle eyes posting on Briskoda this morning Viper:
New MHI2 P470 (2027) maps were released by VW. The content.pkg contains the following FECs/FSCs: 02300040 (Audi), 09300002 (VW), 08300002 (Skoda), 07300040 (Seat), 06300040 (Porsche), 03300040 (Bentley). This also means they'll run on Skoda no problem, as per usual.
Link to the maps on the VW servers: https://navigation-maps.volkswagen.com/vw-maps/Update_25_26/P470_N60S5MIBH3_EU.7z
Will try it later today. This will be the November release but with the faster turnaround in map production due to the monthly release of map updates they have shaved off 5 months or so off production.
As per normal you need the life long navigation FeCs for this. Details in the thread above. Either your friendly retrofitter in East Yorkshire, or Mr Bonks software or 1447AIO or in you were lucky a late release car in 2019 when Seat / Cupra shipped cars with mib2 high / Seat Plus with the life long fecs. This file comes with the navigation FeC of 07300040 if you FeC is less than that in a hex table then its not going to work. You hold onto the menu button and look for installed FeC and reas off the 073 line. Seat life long navigation FeCs end with EE.
