Shock_Xe said:
My train of thought is Aquamist will cost you around £375 by the time you chucked on VAT/Delivery. Then you have to have a resoviour as its not included (for those who dont want to use washer bottle) which will be £x... then there is constant maintencance (refilling etc). Plus the Water intejection is not constantly working as with a fmic, so there is alot of hassle.... So for an extra few hundered quid is it worth the hassle long term for WMI on k0x equipped cars?
I disagree..
Its a no chopping the car about installation for those who dont want to and does have a valid cooling benefit, especially for those with poor intercooling as std.. eg.
Mk3 Ibiza cupras which are rechipped.
Washer bottle is the ideal container, no need to extra one, large 6.6ltr capacity as std on mk3
cupra, and constant maintenance is no more than refilling it just as you have to refill the washer fluid for windscreens anyhow..
On K0x equipped cars, running bigger boost, the turbo's are heat pumps as much as they are compressors, working outside their efficeincy envelopes, so greater heatload if anything.
I know you're making a case for your product, BUT not every one will be prepared to modify they bumpers and metal work to permit fitting of an FMIC.
Aquamist or other water injection systems are a very viable alternative for some people.
If someones thinking about FMIC vs Aquamist & has the money for either and does'nt mind modifying the bumpers and some metalwork behind them, then FMIC is the way to go, no question. No maintenance, fit and forget.
Aquamist also has it place.. and for ref, the price can be from £299+vat from some peeps for System 1S
Bill
