... might check the rear as my central locking isn't popping on two key pushes.
I had exactly this problem - found that disconnecting the battery for a few minutes fixed it.![]()
Sent from my Nexus 5 using Tapatalk
That's the same butyl I got.
When working with it you'll find it pretty maluable and it tends to squidge when you apply the force needed to screw in the door card.
After a night of heavy rain mine seems to have held up fine despite the squidging!![]()
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
Thank you lee I have dried out all of the interior now just got to seal all the doors and seal the bulkhead Then start fixing the other faults ie
Gear box whining
Only blowing hot air out of heaters
Oil leaking might be cam cover might be valve timing unit
