Fitted my coilovers
Driven a few miles and analy measured the height of each wheel arch and adjusted to suit... Nightmare all 4 wheels are now within 5 mm of each othet i can live with that!
:lol: measuring anything anally sounds painful. (Sorry couldn't resist)
Had a busy day fitting
Eibach 25mm front arb
Polybushed wishbones & new ball joints
& gave it a oil,oil filter & diesel filter change :)
Changed oil and filter changed gearbox oil tyre pressures fitted a bov dumpvalve which was a fail
Replaced my broken TCS button with a 2nd hand one off fleabay. Got a new wheel speed sensor too fitting it tomorrow, hopefully that will sort the ABS out!
Cleared the sai fault code, again, despite having fitted 330 ohm, 10 watt resistors for my n112/249 delete?
And established a boost leak, 90 degree hose under Inlet mani... Perhaps that's why she peaks at 1.4 bar then drops to 0.7 bar again.
Fitted a JR Filter, Serviced my 007p, changed my battery, fitted some leds to the low beams enabled auto-windows and fixed my rear washer which had a loose pipe just behind the Cigarrete lighter thing on the boot.
yesterday, gave it a quick machine polish and a wax looked really good. pics in a bit.
also got some smoked side repeaters, auto art ones they said it was for 99-05 leon but the bulb holders didnt fit in?? anyone had experience with that??
Are your holders too big or too small?
Sent from my iPhone
Stage 1 remap yesterday at AMD, and drove away with a massive smile on my face:) Then I went out and burned some V Power around Hertfodrshire.
was yesterday but sorted my car out with ride hight not 100% happy so orderd camber top mounts washed the car as well
These to bring the front in and down
early and late ones have different bulb holders
My bulb holders have a rubber boot around them once bulbholder is in boot goes over the lamp base and cable tie round boot to hold it to holder
Sent from my iPhone
