Don't worry you're not special...they're all fvcked!![]()
It's funny cuz it's true ?
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
You lot know they are there.... but if talent is going to run out I promis to do it properly lolNobody will ever see them (unless you *really* run out of talent) but you'll know they're there, and that's what makes you smile.
on top of the anti rust chemical I've put on i used a zinc spray its very good anti rust, painted it on though after spraying lid, Aldi do really good zinc sprays for the price even as good as Action can ZG-90, then just used the matched paint I've got that does not need a Lacquer, did mine last year as the rust come above the rails , exact same place on both sides, completely forgot as its a common problem the audi S3 mk1 had same issue
watch the rails don't bend as the rubber sticks too body but there easy straightened you just don't want a kink, cleaned them also as certain points hold dirt once paint dry i sprayed silicon spray on the rubbers and fit backI should do that, as I've got a light scuff on my roof I want to sort while I have the 2K lacquer out.
Was it a straightforward job?
This is a job for mine at one point, just picked up a very firm set to replace mine, as a few years ago the garage did not take them out to paint them properly and now the rails are flaking wouldn't av been a big deal except they sealed the ends in I defo expect them to break to get them out
Did you see that PDF doc that someone stuck on one of the Facebook groups??Spent far too long chasing up part numbers and seeing what wonders the Leon Supercopa had. Strangely enough, the stock washer bottle was used as the catch tank for the oil and for actual windscreen washer duties they got the bottle from a mid 80s Scirocco.
Oh, and I found a price list of lots of Supercopa parts at a place in Germany… anyone speak German n wanna ask them some silly questions?
Bedtime reading!!Yeah, that's the one I've been going through, it's interesting stuff... if you're into that kinda thing... which I am ?
