It is mentioned further back what the fix 'may' be, the lip on the inner seal makes contact with the window hence water on the window. this is removed.
Trapper.
Technical sent through info/photos of what was required to the dealer.
From memory, dealer said that currently there is the outer door seal and an inner seal inside the door. This inner seal has a 'lip' at the top of it. What they believe is that sometimes this lip is rubbing against the inside of the window making it wet. The fix was to modify this inner seal to remove the lip.
I think that is about it. I'm going to let them know how it goes, it was OK last night, just hope that is the end of the problem.
They were wet around the middle portion of the window, nothing major and nothing as bad as the front. But saying as they f**ked me about i said i wanted them done too just because it would give them more hassle to do it and maybe they may learn to just fix it as i wasnt going away!! just noticed it one time that rears were streaky!
I need to check mine more often.
I've been really dumb not checking them as I know lots of water pours out the bottom of the doors at times.
In my case it was the front part (by the wing mirrors) of both front windows. I can confirm 100% that Nidd Vale knows how to fix this issue. I can also confirm that Seat UK know how to fix it as it was these guys who informed Nidd Vale how to do it.
For anyone near Harrogate or even willing to travel, you can contact them on 01423 500005. Stand your ground and let them know that you know what you’re on about.
I just picked up my car and they told me they couldn’t hear the alleged rattle!!!! Hmmmmmmmmm a little test drive later and low and behold of the mechanics heard it.
He also let it slip that the SEAT guy is constantly on the phone asking for fixes to various rattles, wet windows and other common faults.
Seat does know about these faults.
Hope it goes well for everyone. I’m still trying to get all the problems with my Leon sorted, its a shame because this is essentially an excellent car.
Good Luck.
Jim
