you spawn a clone! lol...
Two clone's by the look of it Toyotec.
Chris you may not be the only one, but you've got a big head start and who knows what else could be added to yours by next year.
Head is still away gettin done, valves went 2 them the other day...also still waitin on crank, flywheel and clutch cover
Finally got round 2 paying Ben 4 his S2 inlet manifold and i am now
bidding on a set of blue cosworth injectors
S2 inlet manifold arrived yesterday thanks 2 Ben (Ibiza_95)
And also have had a mock up of the supercharger mounts
wow didnt think of mounting it there. might change my plan.
one plan has changed. im going to use the standard manifold and not the s2 one and use leon curpa injectors maybe up the fpr to 4 bar. i'll try and get a pic of the manifold with the rail fitted
here are some pics.
this way i can carry on using the ivs and i dont have to get the s2 manifold welded. which should save a bit of cash
That mounting plate looks like it took time to shape, so before you go making any more you should try fitting it to a mates car as I don't think that's going to fit, it's going to hit the rad and the cross bar that the rad sits on.
