thats fine well mine is the auq engine fella so what cc's are you after? if mine is good with a 4bar then you have them if not let me know cheers
Injectors..... I have some Volvo Si6 engine which is 3.2 Turbo not sure what rating they are but I have some here
:cry: :cry: :cry: :cry: :cry:
I:M NOT THE ONLY ONE ANYMORE :(
fair play though mate, you can be one of my flock, i am the sheperd.
re the clutch, you'll be fine with a new Velua clutch, it'll deal with the power fine matey. Also have you looked at smaller pulleys for the M45 charger? i bought a 19% smaller charger pulley. The ratios will be fine aswell, as the ABF crank pulley is 140mm, the same as the mini cooper S. You'll be fine with the 3BAR FPR aswell mate, i've had no problems what-so-ever with fuel starvation, even at 6.5K (when the fun begins :D). Also my injectors are 350cc (Volvo 230 Turbo injectors) and have had no starvation in fuel. 650cc is WAAAAY to much overkill
The S2 injectors will be fine aswell, and the S2 manifold that Ben (ibiza_95) is trying to sell you will fit straight on, the 1.8T manifold will need cutting and fitting to a lower half of a mk2 golf ABF inlet.
going to be an interesting thread, will keep my eyes on it
ps that charger loooks tiiiight in there
Cheers Chris, thanks 4 the advice and what not...
Hopefully will have the inlet manifold off Ben pretty soon...been abit busy n havent had the time 2 get 2 a computer :lol:
How much did you spend on the mapping n ECU...??
not sure yet i've got standard 0280150464 258cc @3 bar 150hp 20vt injectors at the mo. so not sure what power they'll take. was think of getting cossy injectors think there something like 300 ish cc
but thinking about it my mates cupra runs 220hp on the same injectors. so may just use the ones i got
this is where im at. i've made a bracket
cut down and waiting for my s2 manifold to get welded
20vt fuel rail
i've had a trial fit of the charger to work out how the alternator fits
but i've just bought new rims so im bit skint. so the chargers gota wait
oh and removed a/c
