I fitted my intake pipe. Here is a pic
can i ask where you got the calipers etc and how much for this is on my list as i dont want the power and not be able to stop it. you seem to be doing everything i plan but your doing it before me :cry: would like to see the how the tip helps the performance
I got mine off of fleabay, when searcing, just a little tip, as well as searching for 312mm tt brakes, try audi s3 brakes as well. They are exactly the same parts.
theres not really much in stonegate to know but yea i guess i do,i work there a bit in the summer. i keep meaning to get one of those keys off the bay,bartletts said it would only be £30 to get in coded which is a bit of a bonus. is that a vw key?
Cost nothing to code take the chip out of your spare non remote locking key then get the blade cut put your usual key in ignition then lock car with your new fob and chip easy. Cost me £18 in total and now have a spare key that is remote locking, granted the old spare key is not much good now but who cares!
Key
Yer, it costs absoloutly nothing to do yourself. I had the key cut at my local cutter cost £4, got a Seat Badge from ebay cost £2 and the cost of a key varies,
You can check which one you need by pulling apart your old key, removing battery and there should be a piece of paper with the MHz rating on it, just get a key with the same MHz. :D
This might help http://www.seatcupra.net/forums/showpost.php?p=1133393&postcount=1
Great little mod, much nicer key too :p
Yer there isn't a lot in stonegate? Where abouts did you work in stonegate?
