Haha you guys,
Its really good, the map is so much better compared to what im used to, the boost doesnt hit you all at once and then tail off which is what im used to, she builds upto 26psi then tails off to 21psi, then falls again at 6krpm but i`ve shifted up by then.
Bills done a fantastic job on the mapping really pleased with it no holding back what so ever - really does pin you to the seat. Im taking a couple of members out in it, one tonight and one over the weekend so i hope there post there views.
Overall im really pleased with it, i really need to get the brembos on there tho, it hits silly speeds so quickly and the std brakes just dont seem to cope, i had abit fade last night and i shat myself! My intentions where to get brembos in the next couple of weeks but this has comfirmed it for sure!
Sorry Bill i disagree when you say the standard brakes with uprated pads would cope lol! Your to honest for your own good you should have TOLD me to get brembos ASAP!
Only downside but could also by an upside is that my exhaust manifold has cracked, it seals itself on idle but im sure its blowing open under pressure the upside on that is im proberly alittle bit down on power so once its fixed/replaced theres a little more to come
Im planning on contacting Kinetic to try and get a replacment but i dont think i hold much hope, so it will either be replaced with a THS item or i might try and weld it up and see how long it lasts.
For you that are wondering about the map, i didnt use CC3, ive gone with Badger5 stg3 mapping first k03s hybrid to have been done with this software and i cant praise it enough as far as my knowledge takes me i cant fault it.
Just need to get my lappy sorted so i can run so logs of my own. (when it drys up)
Kudos to Bill for doing a great job and Hooch for fitting the turbo for me!
