Do they illuminate like the std ones?
I hardly ever use my paddles, but I can't see why you would need to extend them in anyway. The product you've bought looks good quality though.
ED
Are you sure you need these ? You dont have your car yet, right ? Th standart ones are big enough (at least for me) Its not only the part sticking out of the steering wheel, there is a whole button behind the steering wheel
these do not replace the std paddles, they are designed to stick to the existing ones, so you'll still see the illuminated (+/-)... There are some that replace but i didn't fancy taking the paddles off.
They just give a bigger surface area which is what i was after, plus i think they look cool....I think i'll be the opposite, most of the time I'll be on the paddles.
Not really sure if I need them, more a case of want them, I'm sure the std ones are more than capable, but these look cool![]()
Spikeydoo, It takes me about 1/4 hour to read one line of your comments!!!for OBVIOUS reasons!!!! I,m NOT complaining though!!!.
Bocawata.
takes me just as long to write em....
Good aint ittakes me just as long to write em....
I've also just got this ....has no real funtional purpose, but should match the pedals nicely.
Got the footrest from a guy on a vdub forum, it's for a golf mk4 - but he was pretty sure it'll fit the ibiza mk5 - but they are on ebay:
http://cgi.ebay.co.uk/VW-GOLF-GTI-R-LINE-MK4-STAINLESS-STEEL-FOOT-REST-PEDAL_W0QQitemZ290390035357QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item439c984b9d
I made my own alloy checkerplate cover for the DSG footrest shortly after I got the car in Oct. The footrest is held on with 1 plastic 10mm bolt at the top, remove and pop the rest out, then you can cover it in anything lying around; leather? wood? carbon sheet? alloy? whatever - mine cost nothing, I cut it out roughly then finished off the edges on the grinder, 2 countersunk screws to hold it on then refit - simples!where did you get this from?
