230bhp without a remap on a 1.4?
a 2.0 tfsi standard 180 making 230 not remapped??????![]()
Poverty are you saying it should be 230 standard on a 2.0 tfsi 180?
thanks for all your input guys.
car now has standard map back on and Forge spacer now off.
it's now as standard as t day it arrived. .
I'm taking it down MK to superchips head office next week and let then do t re map again and run it on there RR.
I did do t spacer up tight but I'm sure that where I was loosing t pressure.
Thank you all for your suggestions. If you still think it could be somethin else pop it on.
I think hes assuming its remaped![]()
Hey guys after all the problems..
I took the motor down to Superchips head office in MK on Friday for them to correct my poor RR results from the other week.
They RR it and the standard results were 252 bhp
They dropped one map on it and it produces the 276 bhp you see on the graph
they then said they would play a little bit more... it then jumped up to 319bhp with 429 Nm of torque.
Its like driving a very different car!! Still not sure if i should put the Forge spacer back on now???
that looks like a good figure, i assume your at stage 2 for that kind of figure ?
was thinking the same Steve.
although superchips rollers do inflate figures.
