Apr 15, 2009
2,188
Midlands
Current Spec
Engine
K03s Turbo Unsilenced
Jabbasport Custom Mapping
Blueflame Exhaust
Blueflame 3" Downpipe (Wideband Sensor Installed)
BKR7E plugs
4bar FPR
LCR/S3 Fuel Pump
Forge UNOS Manual Boost Controller
Jetex Filter
Filter extended to where battery once sat
CAI (from foglight)
Forge TIP
Large Toyo FMIC
Custom Intercooler Pipework 2.5"
Forge Map Sensor Tube
Coldside Relocation
Forge 008
N75 J Valve
N249 & N112 Bypassed
SAI Removed (Forge Blanking Plate)
Carbon caninster (N80) removed
Gloss Black Rocker Cover
Gloss black Inlet Manifold
ProBolt Rocker & Inlet Bolts (Annodised Red)
1.2l Washer Bottle
Battery relocated to boot
Red Hoses
42 Draft Oil Catch Tank
Transmision
VR6 Clutch setup
G60 Solid Flywheel Conversion
Peloquin ATB LSD
Millers CRX Competition oil
Shift Box Mounted Inside Car
Short shift kit
Chassis
AP Coilovers
OMP Front Upper Strut Brace
OMP Front Lower Brace
OMP Rear Upper Brace
Neuspeed Front ARB Kit
Neuspeed Rear ARB Kit
Powerflex Poly Bushed Wishbones
Powerflex Poly Bushed Rear Beam
Powerflex steering rack mounts
Solid Front Engine Mount
Vibratechnics Rear Engine Mount
Vibratechnics Gearbox Mount
Braking
305mm Brembo Conversion
Grooved Discs
Ferodo DS2500 pads
RBF 600 Racing Brake Fluid
Wheels/Tyres
17" 8J Compomotive MO6 in Orange
Toyo T1R's
Exterior
AeroCatch Locking Bonnet Catches
Colour Coded Rear Bumper
8000k HID's
LED Sidelights
Silvatec indicator bulbs
L.E.D Numberplate Lights
LCR Front Splitter
Widemouthed Front Bumper
Debadged
Rear wiper removed
Carbon Front S Badge
Interior
OMP Corsica 330mm Steering Wheel
OMP Boss Kit
Custom Rear Harness Bar (Made By AKS Tuning)
Nomad Twin Gauge Pillar Pod
Autogauge Boost Gauge
Autogauge Oil Temp Gauge
Autogauge Volt Gauge
Autogauge Oil Pressure Gauge
Stack Wideband A/F Ratio/Lambda Gauge
Sony Xplod Headunit Conversion
LED Interior light & LED Map light
Battery in boot
Stripped rear
The Very Start
Thought i may aswell start a thread
Started in July 2009 when i bought the Cupra
Heres some pics from when i picked her up
After owning for 7 months repair bills have now reached the £1000 mark!!
Previous owners had obviously not cared for the car and quite frankly it turned out to have been neglected!
So far ive changed
Brakes all round
2 wishbones
2 anti roll bar links
2 rear hubs
Wheel bolts all round (absolutely kackered threads)
Full interior
Clutch replacement
Repaired clutch pedal
Gear linkage
Previous owner had 17" supperlegerras on, the car then has rear spacers and the standard radius wheel bolts.
Resulting in wheel bolts barely holding the wheels on, damaged rear hubs and bolts all stripped
Interior was seriously neglected and turned out one seat was crooked, it later snapped so picked up a new interior
The rest are just serviceable parts but obviously had just been left leaving me with the joy of replacing them!
Enough of the problems, some more positive things
First to be changed was the gay lexus lights to some nice fresh standards
Then after replacing
Brakes all round
2 wishbones
2 rear hubs
Clutch
Was time for a rolling road
Was off to Northampton Motorsport for rolling road day
It came back with 186.6@ flywheel
and a very healthy 222.7 torque figure
Rather happy with the figures only having a mild map (15psi peak)
Then i focussed on the bay a little bit
Replaced the 007p with a turbosmart
replaced blue vac lines with red
added some more red
Replaced cheap ebay filter with a Jetex
Silicone extension
Coldside relocation
Sprayed strut brace
Heres the engine bay before
Engine bay after
Now just some pics of how the car stands at the minute
Current spec at this point was
Powerflow cat back
Mild Remap (15psi peek)
Laguna FMIC
Jetex filter
Forge TIP
Turbosmart (on coldside)
N249 & N112 bypass
SAI removed
Vac hoses red
Seat sport strut brace
17" OZ Supperleggera
Yoko Pradas
40mm on Koni kit
Nomad pillar pod
Boost gauge
Oil temperature gauge
Future plans
K03s
Blueflame turbo back
stage 2
(hopefully by summer)
Remaining intercooler hoses red
Refurb wheels in gloss black
Thats about it for now!
Looks sweet dude! Glad the seats have gone to a good home :D
Cheers mate
Seats are great, so much more comfortable than my old ones and the are mint!
I have pics to post of my old ones in comparison
Still scary how they hold in by 1 10mm nut lol
Doing a cambelt change next
Then coilovers
Cant decide which to go for though
Have read good reviews on Jamex they seem good for the money
But im not normally one for buying cheap, when it comes to suspension, brakes, tyres etc
But its only for road use so not sure if i want to splash out 500+
Then the wheels will be going gloss black wih a red lip :)
Recently bought a Forge TIP
Fitted it yesterday (wow what a ball ache they are to fit)
I love it so far, has added a nice whistle sound and the power delivery seems so different, almost smoother so im very happy with it!
Compared to standard
Cupra R gauge holder for centre
Picked this up from ebay for £3 lol
slightly modded it to fit as it had a bit of damage at the top but was a very easy fix
got couple more gauges to wire in there and done!
Unfortunately most of the pics are crap as i didnt realise the ISO on ym camera was set to high :(
Car was actually really clean, but camera and photobucket combined did a good job of making it look ****
so selected the very few that turned out ok
Coilovers are now fitted
Will upload some pic soon
Actually like them tbh give a nice rideand compared to the springs and standard shock setup i had its a much nicer ride
Current spec
Powerflow cat back
Laguna FMIC
Jetex filter
Forge TIP
Turbosmart
Coldside Relocation
N249 & N112 bypass
SAI removed
Vac hoses red
Yoko Pradas
TA Coilovers
Nomad pillar pod
Boost gauge
Few new pics of the car and i sprayed the rocker cover black too
Just need to change the blue boost hoses to red ones then i am spraying the inlet manifold and the charge pipe gloss black
Looking Good :)
Do sometimes miss my old Black Cupra :(
Are you going to remove the slats in the front bumper to reveal the FMIC?
I will be yeah, ill be having the bumper resprayed soon so plan is to get it done at the same time.
Dont like the look of it when people just cut it off and leave it looking rough so ill just let the bodyshop do it when they do the spraying :)
Looking good. Do prefer the ibiza's in black or silver. What are the future plans for it mate? You should get some red FMIC hoses to match the engine bay and get it more noticed.
Cheers mate
Im definately changing the blue hoses to red to match the others
Going to get the bumper wide mouthed to reveal the intercooler a bit more too
Then im going to have the inlet and a few other bits done gloss black to finish it off
Was going to sell or px my wheels but think im just going to keep them now, i need 3 tyres but ive been offered some brand new yokos for pennies which i cant turn down so looks like they will be staying and getting a refurb!
Maybe white?
So people do say
But the Turbosmart is a dual port and is still a recirc valve just like the 007p but gives a better sound in my opinion
Its non recirc valves (atmospheric) which are no good for these cars
