Ok what should I be reading on the gauge then? its in PSI
well that would indicate a problem only getting 10psi that was full throttle in 1st and 2nd
phew thank god for that
I was starting to worry, so a good indicator would be a motorway run and see what I get
dont T in from the dv......the dv needs all the vacuum it can get
this is the best place
or if like me you have removd the PCV all together i now use the take off point where the PCV valve hose used to go so my dv valve has its very own line
yep defo mate best place is from brake servo hose
