Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
After countless searches just wondering whats the best place to T in for a boost guage
Whats the pros and cons?
Keep hearing a lot about a green nipple :blink: is this the one down the left side of engine?
Well just T'd into the pipe that goes to the FPR and seems to have worked but is this the best place?
phew thank god for that
I was starting to worry, so a good indicator would be a motorway run and see what I get
you wanna worry when its hitting 5psi limp-home.
look for smooth power and nice boost build. if its not settled clean your dv/recirc, try another n75 and possibly the n275 bypass, as those have sorted my dodgy boost. its grrrrrrrreat now! :happy:
Well not had a motorway run yet but tried in other gears still getting 10psi
Will try the M-Way tonight
dont T in from the dv......the dv needs all the vacuum it can get
this is the best place
or if like me you have removd the PCV all together i now use the take off point where the PCV valve hose used to go so my dv valve has its very own line
yep defo mate best place is from brake servo hose
