Revo Stage 1 Remap Owners - Boost and Timing Levels?
James_LCR
106
Dorset
Just looking to see what boost and timing levels (and with what modifications) you guys are running with for Revo Stage 1 remap.
At the moment I'm running,
- Boost = 7
- Timing = 6
And running on Tescos finest super unleaded (99 ron) with 007p dv and drilled airbox.
Jun 16, 2008
516
Great thread
Forge TIP
Forge Recirc valve
Boost 8
Timing 4
ive found thats the best setting so far...
im curious to try the opposite
higher timing and lower boost - someone on here mentioned that the torque will be more progressive
more testing to come.
James_LCR
106
Dorset
Great thread
Forge TIP
Forge Recirc valve
Boost 8
Timing 4
Well after reading this,
http://www.revotechnik.com/products/pdf/SPS3_advancedUserGuide060406.pdf Page 8, i made my decision. I wish just interested in seeing what others were running.
Look forward to hearing about the tests...
Jun 16, 2008
516
to be honest, that user guide is pants!
but i see what your saying, its a good place to start....
everyone on here will say that you'll need to see the results of on a VAG COM, but thats far too complicated for me.
im just playing around with the settings to see what FEELS better.
is this the second time uve changed the settings?
James_LCR
106
Dorset
Well initially boost was on 9, and I cant recall what timing was on, but i assume that it was around 6. After playing about on the rolling road and after speaking with revo it is now set as above. And feels fine, but saying that the boost was originally set to 8 and timing to 6 and logged with vag-com on the road and all looked good. I had just had the software uploaded so anything felt quicker!
I think the difficulties come when trying to set the boost and timing between the rolling road settings and the actual road especially when seeing high intake temp and the boost dropping off when on the rolling road.
Like you said, I think Im going with what feels good on the road, unless advised any different.
Jun 16, 2008
516
sounds good - if you had VAG COM at hand and the results were fine, then maybe you dont need change the settings....
i found thats boost 9 just doesnt feel right, like im straining the car too much
im thinking higher boost requires some heavy mods.
you say u originally had boost 8, did the VAG COM tests find that boost 7 produced better results?
James_LCR
106
Dorset
Well to be honest, it was set to this on the rolling road to try and obtain some better results but due to high intake temperatures, and having to leave the car to cool we keep it at boost 7 and timing 6...and this has been the first time I've had to try out the car properly on the road with these settings and all feels good...but as I don't have vag-com I can't do any logging, so wanted to see what everyone else was running\advised.
Jun 16, 2008
516
oh right, i see.
rolling road can be a bit hit n miss....
lets see what settings others have on this forum....
who knows, you may see alot with boost 7 and timing 6 - in which case ur laughing :)
btw
it might be an idea to invest in either a VAG COM or Liquid Gauge
i personally have a liquid gauge
its basically a real time monitor that that tells u all sorts - from bhp to MAF to 0-60 runs
youtube it :)
Jun 16, 2008
516
bump.
james, done anymore testing?
in the past month or so ive tried the following
boost 4 timing 8 - Very progressive delivery which was nice, but the overall decrease in power made things slightly boring
boost 7 timing 6 - Thought id try your settings.
quite nice, the torque in higher revs has improved somewhat...... will keep these settings for the next few weeks
Phoenix27
RIP Project Blueshift
Jan 17, 2010
838
Great Yarmouth, Norfolk
Sorry to hijack this thread but i heard a rather worryingthing last night that i need cleared up.....
Is it true that if you get a remap and your ECU 'fails' that you'll lose all your settings? Effectively wasting money? I was sure there would be some kind of guarantee on a remap from AMD/Revo?
Has this happened to anyone or am i just worrying lol?!
revo carl
104
Ok Guys;
No one setting is right for all cars.... all cars are different hence the adjustability! so just be aware of this guys, also setting your settings too high can/will be detrimental as the ECU will see things it's not happy with and will pull out to protect hardware, hence we would always advise logging a car before and after changing settings
Wrong. On ME7 ECU's with revo there is no situation where you would loose your settings unless there was a full ECU failure (in which case I doubt your vehicle would be running) and if this becomes the case there is a lifetime guarantee on the software covering our customers fully
jamandspoon81
239
smoothed airbox with pipercross filter panel and 4 inch air feed,baily atmos dump valve but sometimes baily recirc valve with n75 bypass (depending on moods),forge tip and upper intercooler pipes.
ive tried so many setting i cant remember what is set to now.as said above vag com is probably a must due to all cars being different.interesting to see what other people are running tho.
Jun 16, 2008
516
besides MODS, how can 2 LCR's be so different?
u referring to wear n tear of the engine?
Aug 2, 2009
812
North Lincs
Boost 8
Timing 4
I've never changed the settings since getting the remap.
I find it pretty agressive. The torque in low/mid rev range is impressive.
Phoenix27
Jan 17, 2010
838
That's wicked, thanks for clearing that up mate. :)
Jimz
