Here we go
I'v been meaning to do this for a while
The plan is to just Carbon the top of the box then smooth and spray the rest of it gloss black
Alloy center caps, Before, with laquire peel
Rubbed down ready for Carbon
Looks good I all ready brought some carbon center caps ages ago , not going on the car till the wheels are back or what ever colour I end up choosing
I used the same wax on my wheels as I use on the body work
They were cleaned with Megs Gold Class shampoo,
The car gets washed every week so they werent really that dirty, hopefully I'll get a few coat's of Dodo Juice Red Mist on them over the weekend
Looks awesome D.K! Red mist i am about too order some of that sometime this week
will it give my car the wet look what i am after? I'm just trying all different products,slowly getting more into detailing
If your putting Red Mist over the top of fresh wax, let the wax cure for about 24 hour's before applying the Red Mist other wise it will start to disolve the wax
Wheels look sooo good... cars a credit to ya mate!
Cheers :D
Battery box update
My original plan was to carbon the just the top of the box and then spray the rest gloss black but I decided this was a bit of a bodge so the whole box has now been covered in Carbon Fibre [B)]
Top after 3 layers of clear resin,
Top rubbed down and carbon added to the front and sides of the box
As always I made up too much base coat resin so I had a go at a spare center consul I had knocking around, Don't know how it will come out yet but it's worth a try.
I also finished and fitted my carbon center caps for the alloy's, they look pretty good, I'll get some pictures later.
because 3 tonnes of carbon will make it faster :doh:
Doesn't matter when you have a map that works mate ;)
Right the clear resin coat is on and drying, not really much to show at the moment so I'll get some pictures once it progress' a bit more
Ok these are the part's drying .
They now need rubbing down and smoothing, center consul needs triming to shape then another layer of clear resin a final rub down and then laquireing, so far they look pretty good.
I not given up on the washer bottle cover just yet.
I'v also made some Carbon Fibre center caps
