Finally got around to fitting the 3" TIP and Jabba Heat Shield now its not so cold!
Started off by doing some logs before touching anything:
Code:
Thursday 30 December 2010 17:09:10
1ML 906 032 1.8l R4/5VT 0001
Group A: '003
RPM Mass Flow Load Ign. Timing
TIME
Marker STAMP /min g/s % °BTDC
735.4 4640 10.69 8.6 4.5
748.67 2800 8.58 7.5 6.8
749.09 2800 47.33 29.4 6.8
749.47 2840 65.11 96.5 18.8
749.89 2920 92.78 99.2 15.8
750.38 3080 139.33 100 8.3
750.78 3240 140.83 100 11.3
751.2 3400 136.36 100 11.3
751.7 3600 151.47 100 12
752.1 3760 151.5 99.2 12
752.5 3920 156.39 100 12
752.9 4080 162.22 100 9
753.31 4240 169.75 100 12
753.81 4400 175.03 100 12
754.21 4560 181.28 100 12
754.61 4680 187.5 100 12.8
755.01 4800 190.31 100 12.8
755.42 4960 197.03 100 12.8
755.92 5120 204.61 99.6 13.5
756.32 5240 206.25 99.6 10.5
756.83 5440 211.53 100 12
757.23 5520 212.08 100 13.5
757.63 5640 212.25 100 14.3
758.03 5760 217.03 100 14.3
758.45 5880 212.94 100 16.5
758.94 5960 215.31 100 16.5
759.44 6080 219.11 99.6 17.3
759.86 6200 220.14 99.6 17.3
760.25 6280 216.78 100 17.3
760.65 6200 0 6.3 8.3
761.05 6040 7.22 9.8 6.8
761.55 5760 10.08 9.4 6.8
So took out the old Forge TIP
Fitted the shim onto the turbo with sealant and locktite on the grub screws
Started plumbing everything in
All nice and tight, had to take about an inch of the top 45deg silicone bend
Fitted the jabba heat shield at the same time so everything lined up nicely
And an overall bay shot to finish. Pretty easy job really!
And for the finished logs:
Code:
Thursday 30 December 2010 21:08:12
Group A: '003
TIME
85.07 2680 12.25 8.6 27.8
85.49 2720 48.81 45.9 24
85.89 2760 67.42 98 20.3
86.29 2840 92.61 98.8 13.5
86.7 2960 125 99.6 9.8
87.2 3200 142.75 100 11.3
87.6 3360 133.25 100 11.3
88 3520 145.39 100 8.3
88.42 3680 161.44 100 11.3
88.91 3880 161 100 11.3
89.31 4040 170.83 100 12
89.71 4160 181.33 100 12
90.11 4320 180.92 100 12
90.53 4440 189.44 100 12
90.93 4600 185.56 100 12
91.33 4720 195.19 100 12
91.73 4880 196.25 100 12
92.13 5000 205.42 100 12.8
92.53 5120 207.92 100 13.5
92.93 5240 209.28 100 12.8
93.34 5360 215 100 10.5
93.74 5480 218.36 100 11.3
94.14 5600 218.67 100 11.3
94.54 5680 219.11 99.6 12
94.96 5800 221.56 100 12.8
95.46 5920 223.33 100 15
95.95 6040 223.33 100 15
96.35 6120 222.61 100 16.5
96.75 6200 224.72 100 15
97.15 6320 225.78 100 15.8
97.57 6360 224.61 100 18
98.06 6480 221.19 100 18.8
98.46 6560 221.92 100 20.3
98.86 6600 220.69 100 19.5
99.28 6680 218.53 100 16.5
99.77 6600 11.61 9 9.8
100.17 6480 14.81 11 8.3
So thats an increase of 5g/s ! Feels more responsive and can hear the spool up more now too
Battery was reset during the fitting, so should get better as the ECU adapts
All I need now is the full Miltek exhaust system including 3" down pipe plus a stage two remap
