cos you have a k03
got an K03s but surely it will hold a bit more that 10 psi?
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
cos you have a k03
Well done mate finally getting there .. Hopefully
1ML 906 032 1.8l R4/5VT 0001
Group A: '031
Lambda Factor Lambda Factor
TIME
MARKER STAMP
0.01 0.938 1
0.39 0.938 1
0.9 0.945 1
1.3 0.945 1
1.7 0.953 1
2.1 0.953 1
2.5 0.961 1
2.9 0.953 1
3.32 0.953 1
3.71 0.945 1
4.21 0.953 1
4.61 0.945 1
5.12 0.953 1
5.62 0.953 1
6.02 0.953 1
6.53 0.953 1
6.93 0.945 1
7.33 0.953 1
7.73 0.953 1
8.13 0.953 1
8.53 0.945 1
8.94 0.945 1
9.46 0.953 1
9.94 0.961 1
10.35 0.953 1
10.75 0.961 1
11.25 0.953 1
11.66 0.953 1
12.16 0.945 1
12.56 0.953 1
13.05 0.953 1
13.45 0.945 1
13.87 0.953 1
14.37 0.953 1
14.79 0.961 1
15.28 0.953 1
Sunday 27 February 2011 19:40:40
Group A: '020 Group B: '032
Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization Lambda Lambda
TIME TIME
MARKER STAMP CF CF CF CF STAMP % %
0.02 0 0 0 0 0.42 0.6 -6.3
0.91 0 0 0 0 1.31 0.6 -6.3
1.71 0 0 0 0 2.22 0.6 -6.3
2.62 0 0 0 0 3.02 0.6 -6.3
3.42 0 0 0 0 3.93 0.6 -6.3
4.43 1.5 3 0 1.5 4.83 0.6 -6.3
5.34 4.5 4.5 3 4.5 5.74 0.6 -6.3
6.14 4.5 4.5 3 4.5 6.54 0.6 -6.3
6.94 3.8 3.8 3 4.5 7.45 0.6 -6.3
7.95 2.3 2.3 1.5 2.3 8.35 0.6 -6.3
8.75 3 3.8 3 1.5 9.15 0.6 -5.5
9.57 4.5 3.8 3 1.5 9.97 0.6 -5.5
10.37 4.5 2.3 2.3 0.8 10.86 0.6 -5.5
11.26 3 2.3 1.5 0.8 11.68 0.6 -5.5
12.17 3 1.5 1.5 0 12.59 0.6 -5.5
13.09 2.3 1.5 0.8 0 13.58 0.6 -5.5
13.98 1.5 0 0.8 0.8 14.38 0.6 -5.5
14.8 1.5 0 0 0.8 15.3 0.6 -6.3
15.69 0 0 0 0 16.09 0.6 -6.3
16.49 0 0 0 0 16.91 0.6 -6.3
17.31 0 0 0 0 17.71 0.6 -6.3
18.11 0 0 0 0 18.51 0.6 -6.3
18.91 0 0 0 0 19.31 0.6 -6.3
Sunday 27 February 2011 19:49:07
Group A: '002 Group B: '003
RPM Load Inj. On Time Mass Flow RPM Mass Flow Load Ign. Timing
TIME TIME
MARKER STAMP /min % ms g/s STAMP /min g/s % °BTDC
0.85 2080 77.4 7.48 35.11 0.45 2080 26.94 16.5 29.3
1.76 2200 97 9.52 44.92 1.27 2120 40.31 96.1 25.5
2.56 2320 110.5 10.88 51.92 2.16 2280 48.53 97.3 21
3.38 2480 123.3 11.9 62.47 2.96 2400 56.97 98.8 20.3
4.28 2680 146.6 15.3 82.64 3.86 2560 71.06 100 21
5.17 2960 191 20.4 119.17 4.67 2800 92.42 100 19.5
5.99 3400 191.7 22.44 111.97 5.59 3200 140.33 99.6 6
6.9 3600 179.7 18.7 125.97 6.39 3440 112.03 100 18
7.7 3880 188 20.06 142.83 7.3 3760 133.83 100 15.8
8.5 4200 191.7 20.74 151.33 8.1 4040 150.64 100 17.3
9.3 4480 189.5 20.4 161.81 8.9 4320 156.97 100 19.5
10.21 4840 191.7 20.74 182.25 9.71 4640 175.42 100 20.3
11.01 5120 191.7 21.08 191.58 10.61 5000 189 100 19.5
11.83 5400 187.2 20.06 193.64 11.41 5280 193.69 100 21
12.72 5680 189.5 20.4 201.36 12.23 5560 194.64 100 19.5
13.54 5960 191 20.4 206.25 13.12 5840 205.58 100 20.3
14.34 6160 182.7 19.38 205.92 13.94 6040 206.92 99.6 21.8
15.23 6360 187.2 19.72 209.89 14.75 6240 205.42 99.6 21
16.16 6560 162.4 17.34 210.22 15.65 6480 206.25 100 24.8
17.15 6800 146.6 15.64 209.89 16.66 6680 208.25 98.4 27.8
17.97 6960 151.9 16.32 207.92 17.57 6880 208.72 99.6 28.5
18.96 6840 20.3 2.38 0 18.46 7040 206.67 99.6 26.3
19.76 5520 15 1.7 12.28 19.36 6160 1.67 9.8 6.8
Group A: '115 Group B: '118
RPM Load Absolute Pres. Absolute Pres. RPM Temperature Load Absolute Pres.
TIME TIME
MARKER STAMP /min % mbar mbar STAMP /min °C % mbar
0.4 2600 44.4 1000 1060 0.01 2560 15 0 1070
1.31 2640 48.9 1000 1070 0.81 2600 15 0 1060
2.11 2760 106.8 2290 1350 1.71 2680 17 100 1110
2.93 2960 160.2 2440 1900 2.51 2840 15 100 1580
3.73 3360 191.7 2490 2540 3.33 3120 15 98 2320
4.62 3680 186.5 2530 2260 4.13 3480 13 100 2390
5.54 4000 191.7 2530 2360 5.04 3800 12 100 2270
6.45 4360 191.7 2510 2360 5.93 4160 12 100 2360
7.25 4680 191.7 2480 2300 6.85 4520 12 100 2330
8.05 4960 191.7 2450 2310 7.65 4840 12 100 2290
8.85 5240 191.7 2420 2240 8.45 5120 13 100 2290
9.66 5520 184.2 2390 2270 9.26 5360 14 100 2210
10.67 5800 182.7 2350 2290 10.17 5640 15 100 2280
11.47 6000 171.4 2320 2390 11.07 5880 15 100 2270
12.38 6240 169.2 2300 2280 11.97 6120 15 98.8 2310
13.29 6440 163.9 2280 2390 12.78 6320 16 91.8 2280
14.08 6600 176.7 2270 2220 13.68 6520 17 89 2330
14.99 6760 156.4 2250 2270 14.49 6680 17 86.3 2270
15.9 5840 88 2280 1230 15.4 6640 17 0 2540
16.81 5520 57.9 1000 2540 16.4 5520 18 94.9 2360
I run genesis 430's and they are very smooth. You could use a 4 bar reg on the stock injectors but you risk over stressing the fuel pump.Haha have I maxed out my injectors?on a stock k04?
Would a 4bar for be any good to make them 440cc's??.with the logs what boost am I peaking at...those runs on the guage were showing 23psi peak....
