I tryed another New Dv tonight and the car is still the same...Speaks @ 25psi then tails to 15psi but im getting a fluttering or somesort coming from the engine...When i get this shortly afterwards it settles to 15psi...
going to check the hoses under the inlet manifold tomorrow it can be my Actuator or MBC can it....Static Pressure is set at 9-10psi but bill told me he sets his static pressures to 12psi to keep the gate closed past 20psi+ .....
I Just finished under the bonnet off the car sorting out the wirings,cables ties,vac piping and charge hoses....
They had been abit of a mess since me doing work under the hood so i double checked and inspected all the hoses and jubliee clipped & Cabled tied the vac pipes....
Also Had a split PCV hoses under the inlet which i bodged to secure a new one from seat on monday...with chatting the bill & others ive put the n75 in parrell ( i think) with the MBC so the n75 can control part Throttle Because at 70mph @ just under 3,000rpm its spooling its tits off @ part throttle and alot of surging...
Anyway i think ive done this correctly with the n75 and mbc in together...i havent drove it yet but will do it soon have i done this soon...
hows it looks all the t-pieces look fine? correctly done?
well after a month & 1/2 of pissing around i think ive finally might have sorted this and set it up....
I Tested how ive got the hoses and adjusted the mbc to suit @24psi...now it currently hits 24psi @ just under 3,500rpm then it holds 21psi and as the rev increase the guage needle moves to 20 the 23 then 20 then 23 then 20 and then as the revs go near the back end of 6,000rpm the guage is saying 16-17psi....
But it defo feels quick as the power "Doesnt" tail off it stays there at 5,500rpm which you can still feel in your chest...Also 2nd gear in WOT is saying 21psi peak which is correct for the selected gear is it not?
So result :D im gonna log all the stuff once my D/S wheel bearing is sorted..
But RESULT.....:lol:
I know but its a start Phil...
Drove it again tonight hit dead on the nose @24psi in 4,5 and 6th gear and settle to 20psi..it could be the yuage Phil but its only a few psi between 1-2 at times but it isn't co stand...
What logs do you want me todo Phil? And which ones together..
Do one boost log only so you get the best sample rate. I think both 115 and 118 has an rpm value so either will be fine, if not go with whatever has an rpm value.
I will do that phil...il do a far few once my wheel bearings done next week...
How yours coming along?
I desided to re-fit my GFB 50.50 hybrid which my mate ash has had i havent had this on my remapped lcr at all..so wanted to see what it sounds like at 24psi...
Yeah Id have to agree the MBC cost me £20 posted but i can see why know...Its working well with the n75 now as im guessing the n75 has took over the main objective of controlling the boost...
best of all no 6th gear surging...My gosh that was horrible...
My Wheel bearing has just started to whine could i do a few logs from it?
Ive done some new logs tonight in 4th but with it being a sunday night all i could find was BP petrol station which is 97 ron...:ban:
Anyway anthing i need to change? car on boost was odd tonight?anyway something i can start from i suppose...
Code:
1ML 906 032    		1.8l R4/5VT         0001
	Group A:	'031
		Lambda Factor	Lambda Factor
	TIME
MARKER	STAMP
	0.01	0.938	1
	0.39	0.938	1
	0.9	0.945	1
	1.3	0.945	1
	1.7	0.953	1
	2.1	0.953	1
	2.5	0.961	1
	2.9	0.953	1
	3.32	0.953	1
	3.71	0.945	1
	4.21	0.953	1
	4.61	0.945	1
	5.12	0.953	1
	5.62	0.953	1
	6.02	0.953	1
	6.53	0.953	1
	6.93	0.945	1
	7.33	0.953	1
	7.73	0.953	1
	8.13	0.953	1
	8.53	0.945	1
	8.94	0.945	1
	9.46	0.953	1
	9.94	0.961	1
	10.35	0.953	1
	10.75	0.961	1
	11.25	0.953	1
	11.66	0.953	1
	12.16	0.945	1
	12.56	0.953	1
	13.05	0.953	1
	13.45	0.945	1
	13.87	0.953	1
	14.37	0.953	1
	14.79	0.961	1
	15.28	0.953	1
Code:
Sunday	27	February	2011	19:40:40
	Group A:	'020				Group B:	'032
		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		Lambda	Lambda
	TIME					TIME
MARKER	STAMP	 CF	 CF	 CF	 CF	STAMP	%	%
	0.02	0	0	0	0	0.42	0.6	-6.3
	0.91	0	0	0	0	1.31	0.6	-6.3
	1.71	0	0	0	0	2.22	0.6	-6.3
	2.62	0	0	0	0	3.02	0.6	-6.3
	3.42	0	0	0	0	3.93	0.6	-6.3
	4.43	1.5	3	0	1.5	4.83	0.6	-6.3
	5.34	4.5	4.5	3	4.5	5.74	0.6	-6.3
	6.14	4.5	4.5	3	4.5	6.54	0.6	-6.3
	6.94	3.8	3.8	3	4.5	7.45	0.6	-6.3
	7.95	2.3	2.3	1.5	2.3	8.35	0.6	-6.3
	8.75	3	3.8	3	1.5	9.15	0.6	-5.5
	9.57	4.5	3.8	3	1.5	9.97	0.6	-5.5
	10.37	4.5	2.3	2.3	0.8	10.86	0.6	-5.5
	11.26	3	2.3	1.5	0.8	11.68	0.6	-5.5
	12.17	3	1.5	1.5	0	12.59	0.6	-5.5
	13.09	2.3	1.5	0.8	0	13.58	0.6	-5.5
	13.98	1.5	0	0.8	0.8	14.38	0.6	-5.5
	14.8	1.5	0	0	0.8	15.3	0.6	-6.3
	15.69	0	0	0	0	16.09	0.6	-6.3
	16.49	0	0	0	0	16.91	0.6	-6.3
	17.31	0	0	0	0	17.71	0.6	-6.3
	18.11	0	0	0	0	18.51	0.6	-6.3
	18.91	0	0	0	0	19.31	0.6	-6.3
Code:
Sunday	27	February	2011	19:49:07
	Group A:	'002				Group B:	'003
		RPM	Load	Inj. On Time	Mass Flow		RPM	Mass Flow	Load	Ign. Timing
	TIME					TIME
MARKER	STAMP	 /min	%	 ms	 g/s	STAMP	 /min	 g/s	%	 °BTDC
	0.85	2080	77.4	7.48	35.11	0.45	2080	26.94	16.5	29.3
	1.76	2200	97	9.52	44.92	1.27	2120	40.31	96.1	25.5
	2.56	2320	110.5	10.88	51.92	2.16	2280	48.53	97.3	21
	3.38	2480	123.3	11.9	62.47	2.96	2400	56.97	98.8	20.3
	4.28	2680	146.6	15.3	82.64	3.86	2560	71.06	100	21
	5.17	2960	191	20.4	119.17	4.67	2800	92.42	100	19.5
	5.99	3400	191.7	22.44	111.97	5.59	3200	140.33	99.6	6
	6.9	3600	179.7	18.7	125.97	6.39	3440	112.03	100	18
	7.7	3880	188	20.06	142.83	7.3	3760	133.83	100	15.8
	8.5	4200	191.7	20.74	151.33	8.1	4040	150.64	100	17.3
	9.3	4480	189.5	20.4	161.81	8.9	4320	156.97	100	19.5
	10.21	4840	191.7	20.74	182.25	9.71	4640	175.42	100	20.3
	11.01	5120	191.7	21.08	191.58	10.61	5000	189	100	19.5
	11.83	5400	187.2	20.06	193.64	11.41	5280	193.69	100	21
	12.72	5680	189.5	20.4	201.36	12.23	5560	194.64	100	19.5
	13.54	5960	191	20.4	206.25	13.12	5840	205.58	100	20.3
	14.34	6160	182.7	19.38	205.92	13.94	6040	206.92	99.6	21.8
	15.23	6360	187.2	19.72	209.89	14.75	6240	205.42	99.6	21
	16.16	6560	162.4	17.34	210.22	15.65	6480	206.25	100	24.8
	17.15	6800	146.6	15.64	209.89	16.66	6680	208.25	98.4	27.8
	17.97	6960	151.9	16.32	207.92	17.57	6880	208.72	99.6	28.5
	18.96	6840	20.3	2.38	0	18.46	7040	206.67	99.6	26.3
	19.76	5520	15	1.7	12.28	19.36	6160	1.67	9.8	6.8
Code:
	Group A:	'115				Group B:	'118
		RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar
	0.4	2600	44.4	1000	1060	0.01	2560	15	0	1070
	1.31	2640	48.9	1000	1070	0.81	2600	15	0	1060
	2.11	2760	106.8	2290	1350	1.71	2680	17	100	1110
	2.93	2960	160.2	2440	1900	2.51	2840	15	100	1580
	3.73	3360	191.7	2490	2540	3.33	3120	15	98	2320
	4.62	3680	186.5	2530	2260	4.13	3480	13	100	2390
	5.54	4000	191.7	2530	2360	5.04	3800	12	100	2270
	6.45	4360	191.7	2510	2360	5.93	4160	12	100	2360
	7.25	4680	191.7	2480	2300	6.85	4520	12	100	2330
	8.05	4960	191.7	2450	2310	7.65	4840	12	100	2290
	8.85	5240	191.7	2420	2240	8.45	5120	13	100	2290
	9.66	5520	184.2	2390	2270	9.26	5360	14	100	2210
	10.67	5800	182.7	2350	2290	10.17	5640	15	100	2280
	11.47	6000	171.4	2320	2390	11.07	5880	15	100	2270
	12.38	6240	169.2	2300	2280	11.97	6120	15	98.8	2310
	13.29	6440	163.9	2280	2390	12.78	6320	16	91.8	2280
	14.08	6600	176.7	2270	2220	13.68	6520	17	89	2330
	14.99	6760	156.4	2250	2270	14.49	6680	17	86.3	2270
	15.9	5840	88	2280	1230	15.4	6640	17	0	2540
	16.81	5520	57.9	1000	2540	16.4	5520	18	94.9	2360
Impressive top end boost holding for a stock K04.:)
As i tried to explain to some of the other high powered stock k04 cars, you need to appreciate the limits of the stock 380 cc injectors. @6360 rpm for example your running at an injector duty cycle of over 104 %, yikes! Upgraded injectors are an easy fix.
Haha have I maxed out my injectors?on a stock k04?
Would a 4bar for be any good to make them 440cc's??.with the logs what boost am I peaking at...those runs on the guage were showing 23psi peak....
I run genesis 430's and they are very smooth. You could use a 4 bar reg on the stock injectors but you risk over stressing the fuel pump.
Your airmass figures are low for the boost your running and fuel consumed, can you swap your maff with someone else just to check its cosistancy.
