really? had them off for a while...but they look ok to be honest
what u think of the lego then? did it on a whim to be honest
cupra bushes on....what a difference, handles a million times better,
firmer yes....but also more confidence on corners...
wasabout a 3 hour job, and the old OEM bushes were awful, so much play i could flex them in my hand!
312mm calipers and carriers update.....going to need new brake line from the flexi hose to the ABS pump...seems with the car being lowered it has started to rub very slightly on full lock, means that I might as well change the brake line when I change the calipers. Otherwise I will have to bleed the system twice...hopefully not to dear from SERE or somewhere
um...dont have part numbers, but can find out?>
i just rang sere motors and quoted.."rear bushes for front wishbone on MK4 Cupra...he knew them very well"
must say it is one of the best things i have had done, right pain in the arse to get in and old ones out, only about £17 all in for parts and delivery, paid £100 to get them fitted
oh...and headlight protectors are off...just for you scott!
