if you look carefully through the headlight when refitting your new bulb you can see how close you are when reinstalling the new bulb, the only pain is getting the tiny back panel back on!
splitter back on after the hash winter ripped mine off!....
oh how i missed it!
and decided to do my lego valve caps...did red ones to match the new calipers when they go on!
there not bad, i would have put red ones on tbh lol,
i put led sidelights in today, went in in secs and was able to put the side cap back on in snap the drivers side tho :censored:, i gave up in the end and through it back in the spares box until fingers arent bandaged anymore lol
haha well done Phil!
I have red ones as well, will put them on when the 312mm calipers go on this saturday
Doing LED sidelights soon, when i have a spare few hours!
cupra bushes on....what a difference, handles a million times better,
firmer yes....but also more confidence on corners...
wasabout a 3 hour job, and the old OEM bushes were awful, so much play i could flex them in my hand!
312mm calipers and carriers update.....going to need new brake line from the flexi hose to the ABS pump...seems with the car being lowered it has started to rub very slightly on full lock, means that I might as well change the brake line when I change the calipers. Otherwise I will have to bleed the system twice...hopefully not to dear from SERE or somewhere
You got the part numbers for the cupra bushes? How much were they?
um...dont have part numbers, but can find out?>
i just rang sere motors and quoted.."rear bushes for front wishbone on MK4 Cupra...he knew them very well"
must say it is one of the best things i have had done, right pain in the arse to get in and old ones out, only about £17 all in for parts and delivery, paid £100 to get them fitted
That's where my bro is handy, fitting is free :) , might do them on the fabia, will give Sere a shout next week.
I have some brand new brake hoses if you need them if your replacing the lot, I thought I might need them for the brake upgrade.
